Downpipe attachment point
Old Feb 17, 2007 | 06:19 AM
KRB's Avatar
KRB
What do most guys do about the down pipe hanger when they go bigger?
I have a 3.5" down pipe and the anchor point at the bellhousing obviously doesn't fit/work anymore. I worry that the unsupported weight/flexing/vibrating might eventually crack my turbo housing? Theres 3 hangers on down the line but they are all behind the crossmember. Have ya'll been modifying a clamp to anchor to the bellhousing or am I obsessing for no reason?
Old Feb 17, 2007 | 08:15 AM
hmknight's Avatar
My bellhousing bracket broke off, resulting in the flange on the end of my downpipe snapping and the downpipe falling off. I built a hanger on the transmission crossmember to help with this.
Old Feb 17, 2007 | 08:29 AM
My downpipe is clamped to the stock bracket. The downpipe needs to be secured to the engine/trans assembly, you are right that you don't want the turbine housing taking the load of the exhaust system. Modify/make something that will work like the stock bracket.
Old Feb 17, 2007 | 10:17 AM
ccab85's Avatar
Moved mine down to the hole in the 5-530 position and supprted the bottom of the pipe with a piece of bar stock. Have seen the dowel pins and holes get hogged out with the stock location hanger, then in turn causing all kinds of things to break.
Old Feb 17, 2007 | 01:04 PM
Cowboy_Customs's Avatar
I attached mine to the stock DP attachment point. I just bought a 4 inch exhaust clamp for the 4 inch DP.
Old Feb 17, 2007 | 01:13 PM
90firstgen's Avatar
My 4" downpipe from stan's bolted right to the stock bracket with a bigger clamp.
Dan
Old Feb 17, 2007 | 02:18 PM
KRB's Avatar
KRB
Mine's not in the same position anymore. I'll have to fabricate something.
Shouldn't have bought the cheap version from Texas Diesel Exhaust. Been trouble from the beginning. Live and learn.
Old Feb 17, 2007 | 02:41 PM
1-5-3-6-2-4's Avatar
my 4" MBRP was literally bolt into all stock hangers. super easy.
Old Feb 17, 2007 | 07:55 PM
ChrisLib's Avatar
I welded the mount portion of the original DP to the new one when I did mine, so for so good
Old Feb 19, 2007 | 06:42 PM
kiszka6911's Avatar
Can someone send me some pictures of the downpipe hanger. I don't think my truck ever had one. I finally got the downpipe from stans and want to put things back correct.
Old Feb 19, 2007 | 08:22 PM
90firstgen's Avatar
There ya go! Mind the greasy getrag!
Dan
Old Feb 20, 2007 | 04:07 AM
KRB's Avatar
KRB
Thanks guys. I welded a bracket to a clamp and bolted it to the next lower bellhousing bolt. Thanks for the input.
bngcustoms
Jul 17, 2009 04:53 PM
97catintenn
Jul 12, 2009 05:33 PM
AggiePhil
Dec 27, 2005 04:18 PM
carl20320
Feb 25, 2004 10:45 AM
Lon
Jan 25, 2003 06:56 PM
