Does stock truck need pyrometer?
Old 06-05-2009, 04:45 PM
lumpy_63's Avatar
I tried searching for this but kept getting a memory overflow error? I would like to know if a stock 2002 truck needs a pyrometer? Is it possible to get the EGT high enough to damage something? It is the truck in my signature... Stock except Fass HPFP and aftermarket muffler... Thanks!
Old 06-05-2009, 04:59 PM
HidalgoGT's Avatar
I don't see why it would other then for peace of mind. Other then maybe towing up some extreme hills with weight but even then I would rather worry about an auto's tranny temp then egt's.
Old 06-05-2009, 05:06 PM
Beast2B's Avatar
the H.O. is more susceptible to high EGT on a stock truck than the S.O., but i'd rather know than guess! a nice combo boost/EGT gauge will provide info if you are worried about space for gauges...
Old 06-05-2009, 06:54 PM
12v rollincole's Avatar
I had my pyro on my truck with just exhaust and air intake for acouple weeks and any hill steep enough for it to get above 1000 or so was to steep to stay in OD, so i would see no need. That was on an auto though, might beable to get things more toasty in a 5spd.
now with heavy plate movement/grinding those temps aint so cool any more.
Old 06-06-2009, 09:26 AM
blackimpala's Avatar
I sometimes tow a 34' TT I have at times had to let off the fuel to keep my temps down going up a steep grade, glad I put gauges on.
Floyd
Old 06-06-2009, 09:44 PM
24V-DSL's Avatar
I'd do it just to monitor cool down time to minimize turbo coking.
Old 06-07-2009, 10:51 AM
nickg's Avatar
Egt temp is more vital than tranny temps! you can melt an engine quicker than a tranny.
My dodge truck has been modded from stock pretty much from the first week I got it, my experience has been (other diesels) that even in stock form under certain load conditions you CAN put the engine under enough stress to destroy it, most stock diesels are under fuelled, but with enough load/hill it can exceed safe EGT temps rather quickly, again I cannot vouch for cummins inparticular, but others I can.
Old 06-07-2009, 12:21 PM
stroker4501's Avatar
temps
don't mean to steal the thread but why so???
Old 06-08-2009, 07:20 AM
sheriffav8r's Avatar
Personally, I want to constantly monitor fuel pressure, turbo boost, EGTs, and tranny temp. Once you get a baseline, even on a stocker, you can tell if something starts going bad....
Old 06-08-2009, 08:26 AM
Russ Roth's Avatar
My dodge truck has been modded from stock pretty much from the first week I got it, my experience has been (other diesels) that even in stock form under certain load conditions you CAN put the engine under enough stress to destroy it, most stock diesels are under fueled, but with enough load/hill it can exceed safe EGT temps rather quickly, again I cannot vouch for Cummins in particular, but others I can.
I second everything Nick says. An intercooler leak somewhere can damage your engine also. You may not know it unless you can monitor EGT's.
Old 06-08-2009, 09:32 AM
BigErksG2's Avatar
If it were only that easy... he has a 24v.
Old 06-08-2009, 08:58 PM
lumpy_63's Avatar
Thanks for the advice guys. The last thing I want to do is destroy my engine, I need this thing to last forever!
95black2615
07-17-2012 01:15 PM
nvr-enuf
12-23-2009 06:59 PM
StevenAg03
26
02-12-2007 03:55 PM
VikingDiesel
17
12-30-2006 09:19 AM
00turbo
13
09-03-2004 12:05 PM
Quick Reply: Does stock truck need pyrometer?
