Do I need a boost fooler with my smarty?
Old 01-25-2008, 05:56 PM
Big Horn's Avatar
I am only running the smarty right now and when i tow i only hit 28psi or so and the temps are 1250 to 1350. Would a boost fooler help with the temps, i know the 05 has an electronic wastegate. does the smarty do any boost fooling?
Old 01-25-2008, 06:03 PM
Ghost Ram's Avatar
you have to download the aftermarket turbo program to get more boost. it will disable the electronic wategate.
Old 01-25-2008, 06:06 PM
Big Horn's Avatar
just the aftermarket turbo program, not turbo and injectors? Does this program run good enough with a stock turbo? Thanks
Old 01-25-2008, 06:10 PM
Ghost Ram's Avatar
aftermarket turbo only. aftermarket injector program will add timing i believe. i havent tried the turbo program yet, but bob told me it would run the same only more boost. maybee others will chime in.
Old 01-25-2008, 06:30 PM
Luvnacumns's Avatar
Agreed!!!!!!
Old 01-25-2008, 08:20 PM
jlibert's Avatar
I think the aftermarket injector program would back timing off...
Old 01-25-2008, 08:34 PM
06CTDforAU's Avatar
That's what I thought because aftermarket injectors advance the timing. Therefore the Smarty takes this into account and reduces timing in it's programs.
Old 01-25-2008, 08:36 PM
TORQUE BEAST's Avatar
that's right. aftermarket injector program has less timing.
Old 01-26-2008, 03:24 PM
Big Horn's Avatar
is anyone running the aftermarket turbo stock injector program with a stock turbo? I don't want to loose the version that I have if this doesn't work well.
I think that the latest one is Dec. 13th.
Old 01-26-2008, 04:57 PM
jgiachino's Avatar
You definately want to run the aftermarket turbo / stock injector program....it's much better than the stock turbo / stock injector programs
Old 01-26-2008, 09:47 PM
Big Horn's Avatar
I guess i'll give it a try then. Thanks, anyone else who has run it want to chime in?
Old 01-26-2008, 10:03 PM
jgiachino's Avatar
It'll take you from a max of low 30's psi boost to 40+ psi....and it spools the turbo faster (diff fueling curve)....
Old 01-26-2008, 10:10 PM
JohnInNH's Avatar
Just watch your Boost PSI You can easily go past the 42 PSI limit (that's MY personal limit) I feel any more and it's starting to get out of the efficiency range and you are blowing hot air. I usually start to let off at around 38-40 PSI. I don't let of quickly but ease off. This helps prevent turbo bark.
Old 01-26-2008, 10:18 PM
Big Horn's Avatar
When i ran the juice/att. I would usualy back off when i hit 38psi, I think your right, anything over 40 for to long is pushing it.
Killdmycobra
11-12-2010 05:15 PM
BigBully
09-15-2009 08:44 PM
nrussell
01-13-2008 07:00 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: Do I need a boost fooler with my smarty?
