what do i do next
Old 10-05-2011, 02:32 PM
rustydeeretech's Avatar
what do i do next
looking to do some more work to my 96 and 91 should i do the valve springs and then stud it or the other way around , also if i just fire ring it do i still need to put studs in it . i want to start makings so real power out of them but want to take the right precautions b4 i scatter something thanks neal
Old 10-06-2011, 01:25 AM
Tate's Avatar
O-ring the head, do the valve springs when the head is off, use studs when you install. Save up and do it all at once, will save you re-doing the work.
Old 10-12-2011, 08:53 AM
loudonredskin09's Avatar
id just get fire rings ,use stock head bolts and then get 60lb valve springs and titanium retainers maybe port the head on the exhaust side a little my old truck had this set up and ran lil over 600hp
CurtisvilleCummins
03-10-2003 02:24 PM
02-20-2003 08:17 PM
Fillerupsonny
11-21-2002 08:51 PM
Dusty 96
10-13-2002 06:54 AM
Quick Reply: what do i do next
