Correct ECM (Cold Start Module) For 1990 Truck
Old 12-26-2009, 08:50 PM
partyrider's Avatar
I have a 1990 auto trans VIN 1B7KE2683LS605089. I am having issues with intermittent cycling of the grid heaters. Ran the Alldata test protocol and it seems to indicate a bad controller. Harness seems OK by visual inspection and sometimes the heaters will cycle correctly. Can anyone provide any insight? Also, the correct ECM for this truck is....? I need the one that works at 59 degrees. Any help appreciated. Thanks.
Old 12-26-2009, 08:55 PM
G1625S's Avatar
welcome to dtr! No ecm in a 90, I don't think. There's a little black box on or near the firewall that runs the grids, iirc. I'm a little out of the 1st gen loop, so I could be way off base. Someone smart will be here shortly, lol! What are the symptoms?
Old 12-26-2009, 09:11 PM
partyrider's Avatar
That little box located below the brake booster is what is giving the problems.
Old 12-26-2009, 09:43 PM
14racing's Avatar
Maybe you should check your intake temp sensor. ECM's rarely go bad. If its not receiving the correct input than your output will not be correct. Just a thought. I'm not real up on how the grid heater system functions because i've never had a problem with one.
Old 12-27-2009, 09:42 AM
partyrider's Avatar
I have swapped out the temp sensor ( thermistor) and the system behaves the same way.
Old 12-27-2009, 11:28 AM
sdstriper's Avatar
Grid heater control module or Cummins calls it Heater Control Module, it's on the drivers side firewall.
Old 12-27-2009, 12:55 PM
HMARK's Avatar
About 3 years ago I had the problem where the intake heater would work sometimes, after checking all of the parts before and after the ecm it ended up being the ecm. I found a used one on the internet 150.00. Check and make sure everything is grounded well.
Old 12-27-2009, 01:00 PM
The old 15 degree controllers are superseded, you won't get one of those.
I knew I had researched this recently, but it took me a while to find it.
See:
https://www.dieseltruckresource.com/...79&postcount=4
5.9Excursion
Cummins Conversions
03-20-2008 04:47 PM
2rowdy
44
11-06-2007 09:39 AM
3500eh
04-09-2007 03:13 PM
RAM2940
10-22-2006 03:08 PM
APD
03-03-2005 05:39 PM
Quick Reply: Correct ECM (Cold Start Module) For 1990 Truck
