coolant drain plug
Old 01-11-2009, 01:16 PM
snowwjob1's Avatar
coolant drain plug
Ok i have a question on the drain plug i thought it was on the drivers side bottom, it looks like there is a hose barb and a ball valve of some sort. I turned it and nothing drained. I did open the radiator cap but nothing come out any suggestions?
Old 01-11-2009, 01:34 PM
98whitelightnin's Avatar
Is your truck a stick shift?
Old 01-11-2009, 01:54 PM
can17's Avatar
You have to turn it a little and pull out, then turn a little more and pull again. May have to use pliers.
Old 01-11-2009, 04:16 PM
Dartmouth 12V's Avatar
If you just turn it, nothing will drain. You have to turn it 90 degrees while pulling hard. I think that it is a bad design because it takes a lot of force. It will come out a significant amount, you can't mistake it when you get it.
Old 01-11-2009, 04:43 PM
GAmes's Avatar
It is easier to siphon the coolant out and you won't have to worry about ruining the 0-ring. Makes less of a mess too. The system holds 6 gallons, you need a big bucket.
Old 01-11-2009, 05:50 PM
infidel's Avatar
I just remove the lower radiator hose.
Too many problems with the drain plug, either it needs a new o-ring or it breaks.
Old 01-11-2009, 07:30 PM
klx650a2's Avatar
Mine was stuck REALLY hard also, I just siphoned all the antifreeze out, then removed the lower rad hose. You'll need a 5 gallon pail and then a smaller one, I think the system holds 25 some old liters... or 6ish US gallons...
Bad design by dodge or cummins or whoever made the stupid thing...
Rancher99
03-13-2011 05:42 PM
klx650a2
01-10-2008 12:08 AM
fitzydog
20
11-13-2007 03:50 PM
ozzie
11-10-2003 08:13 PM
wooff
05-01-2003 11:22 AM
Quick Reply: coolant drain plug
