Coolant drain
Old Nov 10, 2003 | 03:10 PM
ozzie's Avatar
Coolant drain
On a 2002 Ram is there a stopcock for the radiator so I can drain and flush my system??
Old Nov 10, 2003 | 03:17 PM
Scubasteve's Avatar
Re:Coolant drain
There is and its on the right side of the rad if I remember correctly. To be honest I woud suggest getting a 5 gallon pail and just pulling the lower rad hose off, I found this much easier than trying to use the drain **** on the rad.
Good Luck
Jason
Old Nov 10, 2003 | 03:20 PM
DODGE4X4's Avatar
Re:Coolant drain
There is a drain plug on the bottom left. It is right below the lower turbo boot going into the inercooler. Just trun and pull back it should start flowing. Take off you radiator cap it helps the fluid to flush out.
Old Nov 10, 2003 | 03:22 PM
DODGE4X4's Avatar
Re:Coolant drain
While I was typing I lost the post race.
Old Nov 10, 2003 | 03:24 PM
ozzie's Avatar
Re:Coolant drain
I knew there had to be one somewhere. I do like the idea of taking off the lower radiator hose. I did that on my old 92 and it drained out in only a few minutes. Thanks a ton!!!!
Old Nov 10, 2003 | 03:40 PM
Ramflasher's Avatar
Re:Coolant drain
Go gently with that drain! They break easily, and turn hard!
I think it turns 1/4, then comes out a bit, and turns some more....
Old Nov 10, 2003 | 08:13 PM
Scubasteve's Avatar
Re:Coolant drain
Snap it off and you will be large cash in the hole. Seen that happen before. Cant beat pulling the hose as its safe and easy.
Jason
klx650a2
Jan 10, 2008 12:08 AM
mowin4dodge
Nov 13, 2007 06:28 PM
fitzydog
20
Nov 13, 2007 03:50 PM
Tazman
Dec 22, 2004 12:44 PM
wooff
May 1, 2003 11:22 AM
