Code Readers Scan tools
Old 03-14-2004, 09:12 PM
TEXASTURBO's Avatar
I am looking for a scan tool for clearing my codes and troubleshooting. I found two the acutron at Autozone and one online called a OBDII the both read PO codes and PI codes
Can i clear everything with one of these ? Im under warranty and sick of the dealer, I dont want a Hypertech , I have a comp box waiting to install , But i need to get the bugs i have worked out before using the comp , I know it will void the warranty if the wire is tapped , But can they tell the plate has been on it? if i pull the comp and plate? Also will the Comp cause any codes i cant clear ?
Old 03-14-2004, 10:42 PM
Haulin_in_Dixie's Avatar
The yellow Autozone units will clear the codes as well as read them. I have one, works good.
Old 03-15-2004, 10:09 AM
thumper 549's Avatar
Snap on sells them
Old 03-15-2004, 10:28 AM
Originally posted by thumper 549
Snap on sells them
Only trouble with Snapon, they have great tools but get confused when adding zero's to the end of the price.
Old 03-15-2004, 06:29 PM
TEXASTURBO's Avatar
I bought a ODII from Oreilly , I think it works ? I cleared the codes and all i can see now is the 0216 , I tried the key method and i dont get anything unless i drive a block then the 0216 comes back , So i guess it works ,
Thanks guys
Old 03-16-2004, 05:03 AM
Gman77's Avatar
Any Canadians have the Crappy Tire OBDII reader?
lifer
12-26-2007 10:44 PM
Dale_K
10-18-2007 02:57 PM
billyfish
24
07-23-2007 09:48 AM
BDR2500
01-18-2005 04:55 PM
dctoner
03-15-2004 10:11 AM
Quick Reply: Code Readers Scan tools
