Closed RWAL Valve Switch
Old Mar 26, 2005 | 07:07 PM
Begle1's Avatar
Howdy,
My "Brake" and "Anti-Lock" lights are stuck on at all times... I grounded out the black wire to get the error codes and got 4 flashes. Based on information posted here in the past, that means that the RWAL valve switch is closed...
But what is the RWAL valve switch, where is it and how do I open it?
Old Mar 26, 2005 | 07:13 PM
rebal's Avatar
rwal is rear wheel anti lock its in the frame at the L rear of the truck ...follow the steel line off the axle and it will lead to it ... Have you tried to unplug the modual behind the glove box yet (about 30 sec. is all ) to reset it?
Old Mar 26, 2005 | 08:36 PM
Begle1's Avatar
I know what RWAL is, but what is the RWAL "switch"? The code said the switch is bad; where us this "switch"?
Isn't the thing on the frame the "valve"?
Old Mar 27, 2005 | 01:46 AM
rebal's Avatar
there are 3 switches built in to the rwal valve ,service manual states control valve is not repairable 1is reset switch 2 is dump sol. 3 is isolation sol. as best as i can tell is to un plug modual for 30 sec. to reset the system none of the antilock parts are serviceable it consists of sensor at dif. modual,and hyd. valve .
thats all i can help you with hope it helps
Robert
Old Mar 27, 2005 | 06:08 PM
Begle1's Avatar
So in other words, if the switch is indeed broken I need an entire brand new valve?
Old Mar 27, 2005 | 06:55 PM
rebal's Avatar
thats how I read it . Did you try and unplug the module yet?thats the only thing I can find in the FSM to reset the system
Robert
Old Mar 27, 2005 | 07:35 PM
edwinsmith's Avatar
I think that's the same code I get on mine but I'm waiting on warmer weather to crawl underneath. I'm hoping it's a loose or shorted connector or wiring though. It's no telling on my truck. I found the entire left back brake had been gutted!
So check out all the wiring and reset the module by unplugging for 30 seconds and see if it works again.
I don't accept that the valve isn't servicable. I am adept enough that sometimes I can fix these things that Chrysler just replaces because it's cheaper for them and more profitable to sell the whole assembly than a repair kit. It's like them saying they will only sell you a new engine rather than selling you a water pump.
Edwin
Old Mar 29, 2005 | 04:41 AM
jughead's Avatar
Edwin if you find a way to fix that problem would you post it here. mine has been that way for 4 years. rwal valve was 150$ 4 years ago which i would have bought but if it didnt fix i was stuck with it. dealer techs were a bunch of parts changers. not iknocking all techs. been there done that myself for 10 years. there are some really good ones out there. electronics aint my forte.
Old Mar 29, 2005 | 12:12 PM
edwinsmith's Avatar
It might be a while but yes I'll post it here.
Old Apr 6, 2025 | 10:00 AM
Pcleaners2's Avatar
Rwal dump valve 97 ram diesel
where is this dump valve on the 1997 model. I only can find the proportioning valve. Have the same problem 4 flashes from datalink , replaced mc and reset module.
Originally Posted by Begle1
Howdy,
Old Apr 6, 2025 | 01:47 PM
u2slow's Avatar
On the 95 I wrecked out, it looked like an extra prop valve with a couple solenoids on it.... Below the MC area.
Old Apr 8, 2025 | 06:37 PM
Pcleaners2's Avatar
Rwal
When resetting abs module is that done with truck on after pulling plug ?
BearKiller
Oct 12, 2014 07:21 AM
bigragu
Sep 6, 2014 02:32 PM
Oracle12345
Oct 2, 2009 08:05 PM
dIlLiGaF
Apr 15, 2005 03:16 PM
