RWAL controll valve
I need to replace my RWAL control valve. Can any one tell me if the brake bleeding procedure is the same as non abs brakes and do I only have to bleed the back brakes? One last question, has anyone used the speed bleeders that are available from russell and if so do they work as advetised?
Ya, unfortunetly some moisture got into the eletrical connection on the control valve and shorting it out taking the control module with it. I was able to pick a module from a wrecked 1500 but the valve is a dealer only item. Should use the speed bleeders or am I better off to invest in a presure bleed system?
newtododge
Mar 25, 2006 08:15 AM
