1992 one ton
Old Apr 8, 2025 | 07:16 PM
willy wagon's Avatar
1992 one ton
this is what my one ton has on front diff, for steering alignment
Old Apr 8, 2025 | 07:57 PM
u2slow's Avatar
Looks like this kit:
https://drifthq.com/en-ca/products/s...uxvZ6e_HvundYi
Did you mark it on disassembly? That will be your clue as to the correction it provided.
Edit: that kind thing is often used as a 'fix' for a bent housing, or one that wasn't built perfect.
Old Apr 8, 2025 | 09:10 PM
1992 one ton
i didnt take it all apart so that everything went back to where it was. it is next going to alignment shop. also tomorrow i am going to try and see if i can determine if housing is bent. that is where i am at presently
Old Apr 8, 2025 | 09:54 PM
u2slow's Avatar
Do point out to the alignment shop you have this adjuster type, since it's not factory.
Old Apr 8, 2025 | 11:05 PM
1992 one ton
oh for sure i will. so whey do you think these kits are used. are they stock on the chev, or Ford diff do you know?
Old Apr 9, 2025 | 01:02 AM
u2slow's Avatar
Nobody used them. They are aftermarket. See post #2 for reason.
Nick & Kels 08
Apr 18, 2011 09:16 AM
sixb
Mar 5, 2009 08:13 PM
LanceD
Off Road / 4x4
Feb 6, 2007 09:34 PM
