Cb antenna mounting
Old 06-01-2005, 07:49 PM
nauitque21's Avatar
Cb antenna mounting
i plan on running daul antennas on my truck and was wondering where you all mounted yours?
pics would be cool!!!!
-Bryan
Old 06-01-2005, 08:06 PM
kevellis32's Avatar
i have mine mounted to my bed rail right behind my cab, if you look in my gallery you can see a good picture of it
Old 06-01-2005, 08:24 PM
DieselDaze's Avatar
Ive got two Wilsons mounted in the same location as Kevellis.
The cab does create a shadow on both antennas. However, I have not had any issues with this.
Mounted in parallel, I understand that it creates a range that is focused forward and back (as opposed to side by side range) and the cab can decrease forward range thus hurting the effectiveness of the antennas.
If you mount them in the bed, behind the cab, be sure to go with a top loaded setup.
Some good info HERE.
If you really want a good set up, be sure and do some research. There's a fair amount of info on the net about different mounting solutions and the pro's and cons.
Rich
Old 06-01-2005, 09:58 PM
Cummins4Life's Avatar
I have my single in the same place as above. Cheapo 4' firestik and it works well for what I use it for. Used one of the fender mounts to attach it to the bedrail. Didnt like the look with it upfront. And suprisingly that close to the cab SWR is below 1.5 on all channels.
http://webpages.charter.net/235460/antan1.jpg
http://webpages.charter.net/235460/antan2.jpg
Old 06-01-2005, 10:35 PM
Buckshotmckee's Avatar
I have my single wilson mounted in the center on the bed rail, no problems, good reception. I got pic in my gallery.
Old 06-02-2005, 01:02 AM
phox_mulder's Avatar
Firestik Dodge Ram hood mounts for mine.
Uses existing bolts, just remove bolt, put the mount on, replace bolt.
For some reason, the bolt closer to the windshield wouldn't work on mine,
the bolt was too far from the edge so the hood wouldn't close.
phox
Old 06-02-2005, 05:53 AM
CTD NUT's Avatar
Twin Wilsons mounted on my own custom back rack.
Old 06-02-2005, 05:57 AM
CTD NUT's Avatar
doh!!! can't figure out how to get the pic to show.....it is in my gallery anyway......
Old 06-02-2005, 06:32 AM
hotdram's Avatar
Used these brackets on each side of my crossover tool box:
One is for the CB, the other for the scanner.
~Rob
Old 06-02-2005, 08:40 AM
DodgerDoob's Avatar
Does anyone make a mount that clamps to the bed rail. I don't want to drill any holes in my truck.
Old 06-02-2005, 08:53 AM
CTD NUT's Avatar
DieselDaze,
Thank you for sorting out my picture problem and computer ignorance!
hotdram's Avatar
Is this what you are looking for?
Click Here
OR
This is for the stake holes:
Click Here
~Rob
Old 06-02-2005, 11:03 AM
nauitque21's Avatar
thanks for all the replys you guys!
all of the pics look great! i like the ones that are behind the cab. i like the mount that connects to the bedrail and puts it out a bit. that way i can still put a crossover box or a canopy on and not have to take off the antennas.
i'll look into them more. i think i can make them pretty easy. i like the mounts on the rack too!! maybe i'll upgrade to that later.
-Bryan
Old 06-02-2005, 05:56 PM
Meatball's Avatar
Old 06-03-2005, 01:05 PM
nauitque21's Avatar
Originally posted by Meatball
that's a pretty crazy looking exhaust you got going there. get a lot of droan in the cab???
i bet it sounds sweet though.
thanks for the pics!
I SPEED
10-26-2004 07:15 PM
KSwanner
07-21-2004 03:29 AM
silverbullet02
07-07-2004 08:52 AM
Goldenbear
04-09-2004 05:57 PM
surfram
02-12-2004 07:20 AM
Quick Reply: Cb antenna mounting
