Can't disable Seat belt chime
Old Nov 2, 2006 | 04:35 PM
dtrkstan's Avatar
Need your help. Had a new tank lift pump installed and fixing dealer wiped out my flashes that had the high idle enabled. I took it to my selling dealer for a reflash which he did and they activated my high idle but said they had to do the back-up recall even though I asked not to have it. Sorry for the long intro,but now I took out my manual and tried to deprogram that seatbelt dinging.Question: Did this new flash over -ride my disable,or am I doing something wrong,out of order or what? Does it have to be started or just turn the key to the on position? I use my seatbelt on highway but not on the farm.Really nice during Deer season. Might as well blow off fire crackers and light some early morning flares.
Old Nov 2, 2006 | 04:40 PM
iker42's Avatar
It takes many tries, just to discourage you...
Old Nov 2, 2006 | 07:21 PM
phloop's Avatar
When you do this, do as the instructions say, just do NOT do it "more times". I think the instructions say 3 or more times within so many seconds. Do not do the "or more times", only the three times. I had a fit with this on my '04.
Old Nov 2, 2006 | 08:12 PM
JMalone's Avatar
Yup... I did mine just the other day... Three times exactly. Just don't rush yourself. Just try a few more times.
Old Nov 3, 2006 | 10:08 AM
dtrkstan's Avatar
Thanks guys,I'm away from my truck for about a week but I'll give it a try ASAP.
Old Nov 3, 2006 | 02:13 PM
pooperscooper's Avatar
isnt there an adendum for the 06's, i belive it is a different procedure than what the owners manual says....maybe not.
Old Nov 3, 2006 | 09:13 PM
FastTaco's Avatar
I got tired of mine dinging so I took the plug loose at the seatbelt latch, stripped a little of each wire, then twisted them together and taped it up. No more ding!
Old Nov 3, 2006 | 09:53 PM
JMalone's Avatar
I got my directions directly out of the '06 Owner's Manual.....
Verbatim from the Manual:
1. With all doors closed and the ignition switch in any postion except On or Start, buckle the driver's seat belt.
2. Start the engine and wait for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle and then re-buckle the driver's seat belt at least three times within 10 seconds (I did it exactly three), ending with the seat belt buckled.
4. Turn off the engine. A single chime will sound to signify that you have successfully completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated by repeating this procedure.
NOTE: Although the Enhanced Warning System (BeltAlert) has been deactivated, the Seat Belt Warning Light will continue to illuminate while the driver's seat belt remains locked unbuckled.
banyon
22
Mar 19, 2012 08:02 PM
daddykevin
17
Jan 25, 2007 10:29 AM
Mallard
May 15, 2006 10:56 PM
339K&Counting
Jun 6, 2004 12:13 AM
Lightman
Oct 27, 2003 04:08 PM
