A/C leaking down - HELP
Old 07-26-2005, 09:47 AM
Mcmopar's Avatar
Guys,
My A/C is leaking down on me, I keep recharging it, its OK for a bit and then goes south again. I put die in the system, then use the UV light and cannot find a leak at any of the fittings, lines, or the condenser?? How do you guys get to the exchanger under the dash to see if that is the culprit?
Old 07-26-2005, 09:59 AM
PistolWhipt's Avatar
I believe you have to take the dash apart to get to it ...that's how they found mine. if you haven't done a search on here yet, try that ... this is a common issue that has been dealt with before.
Cheers,
PISTOL
lilsuzuki4x4
09-01-2011 01:50 AM
DAN POUCHER
06-14-2008 06:52 PM
DAN POUCHER
05-07-2008 07:23 AM
CORed
09-20-2006 08:25 PM
Quick Reply: A/C leaking down - HELP
