Boost gauge question
Old Jul 7, 2004 | 09:10 PM
Quink's Avatar
I have a 04 CTD and want to install my gauges. my question is where do connect the boost hose connector into the motor? My 02 CTD was easy just took the 3/4'' plug out and installed the new fitting. I do not see the same plugs on the intake with this one. Any ideas??
Old Jul 7, 2004 | 11:38 PM
Maccandy's Avatar
I used a "Tapped Intake Manifold Bolt" from Geno's Garage. It was with the gauge I got from them.
Old Jul 8, 2004 | 07:57 AM
WA4SLC's Avatar
My X-Monitor came with a hollow manifold bolt. I took out the bolt closest to the front of the engine and put in the bolt they sent. The bolt has a device on the top that you just slide the tubing into and it is ready to go. It was much easier than my 01 was.
Bill
Old Jul 8, 2004 | 10:20 AM
nickleinonen's Avatar
i took off my intake horn and drilled & tapped it. simple and free...
Old Jul 8, 2004 | 04:03 PM
bhoeffner's Avatar
I did the same thing Nick did, drilled and tapped the intake horn. easy mod
Old Jul 8, 2004 | 05:50 PM
tcr's Avatar
tcr
Drilled and tapped the horn also, easy,easy,easy.
Old Jul 8, 2004 | 08:45 PM
Quink's Avatar
Thanks, I will try tapping the intake. I plan on doing it this weekend.
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
