Boost Elbow with a Smarty ???
Old 04-29-2007, 04:06 PM
qwest's Avatar
Would a Boost elbow doing anything positive with a Smarty. ???
Old 04-29-2007, 05:07 PM
graphitecumnz's Avatar
You need the boost elbow to allow the wastegate to open at higher boost pressure as opposed to the stock levels.
Old 04-29-2007, 06:04 PM
phox_mulder's Avatar
You most likely won't have enough fuel to need the boost elbow with just a Smarty.
Bigger injectors along with the Smarty, and the boost elbow will be a good thing.
phox
Old 04-29-2007, 06:11 PM
Big Dblue's Avatar
how much is a boost elbow. I was lookin at Tst's websit. but i couldnt find it. I am going to call them tomorrow.
Old 04-30-2007, 12:32 AM
Ph4tty's Avatar
Here's a link Blue. $25 from Tst. Took me all of about 15 seconds to find it =P
http://www.tstproducts.com/index.asp...PROD&ProdID=33
Old 04-30-2007, 06:18 AM
BIGHEAD's Avatar
Just put a tack weld on your waste gate & you won't have to worry about the elbow or wastegate.
Old 04-30-2007, 09:36 AM
MSquare's Avatar
You don't need one with a Smarty.
Old 04-30-2007, 09:47 AM
Mike D's Avatar
Not true, You'll need something to control the wastegate for more boost.
The Smarty has a boost fooler to prevent codes.
Old 05-01-2007, 10:09 PM
MSquare's Avatar
Oopps, my bad. You are correct, I typed before I thought!
Old 05-02-2007, 12:34 AM
Ph4tty's Avatar
Um, tack weld it? I just used a pipe plug where the elbow was to disable the wastegate and when I want to run a wastegate again I just have to put the elbow back in =P
Old 05-02-2007, 06:01 AM
lsgibb's Avatar
This is what I'm running. With just a Smarty you won't get more than ~30psi out of an HX-35 so just go to a hardware store and get a plug for a couple of dollars. Now if you ever add anything else to it you will need an elbow to allow the wastegate to open up around 35psi.
Old 05-02-2007, 06:11 AM
qwest's Avatar
Thanks all, Think I will run it one trip loaded and see how it does,
dodgediesel
12-14-2006 09:54 AM
TorqueJunkie
15
08-30-2006 09:15 PM
RockcrawlingTJ
07-22-2006 05:11 PM
triplenickel
08-23-2005 04:01 PM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: Boost Elbow with a Smarty ???
