Bhaf
Old 02-18-2010, 12:40 PM
SIXSLUG's Avatar
Bhaf
How often do you guys change out your BHAF? Mine is kinda gray but overall still pretty clean as far as sight goes. Its been in for about 2 years now.
Old 02-18-2010, 05:53 PM
rattlebox01's Avatar
How many miles are on the filter and do use a outerwears or similar prefilter? That may be a better indication than how long you've had it.
Old 02-18-2010, 10:40 PM
BRO
BRO's Avatar
What does the inside look like? I have read of guys saying 50K miles and still looks good but I have no idea. Mine is not that old, but I wonder how long they last as well.
I guess if it is freeway driving and not a lot of dusty, sandy riding and using the outerwear's it would last for some time.
Old 02-18-2010, 10:46 PM
johnh's Avatar
i cleaned mine w/air pressure from the inside last week......I'm good for another 80,000 miles
Old 02-18-2010, 11:14 PM
BRO
BRO's Avatar
johnh, did it blow a lot of dust out or was it anti-climatic?
Old 02-19-2010, 10:36 AM
ldornak's Avatar
I put 2 years and 40K on mine without a prefilter. When I replaced it, I compared the old to the new by looking at the inside of each. There was a noticeable difference in how much light was allowed to pass through each. I installed an outerwears prefilter on the new bhaf.
Old 02-19-2010, 02:53 PM
johnh's Avatar
a lot of dust
Old 02-19-2010, 10:37 PM
I know that a lot of people do it but it is a general reccomendation to not used compressed air on air filters and says so in some maintenance logs becuase it can damage the media causing it to flow considerably less air.
Old 02-20-2010, 12:19 PM
SIXSLUG's Avatar
I'm at around 30K. It looks pretty good on the inside still.
Who sells the "outerwears"?
I have also read not to use compressed air on these because when the air carries out the debris it can damage the filter media creating gaps that will let larger particles pass thru.
Old 02-20-2010, 01:51 PM
Moparmax's Avatar
http://www.outerwearsracing.com/prod....asp?prod=2086
Old 02-20-2010, 02:36 PM
OldDodgeOwner's Avatar
I've got 25K miles on mine. Added the Outerwears at some point in the middle. I pull it off every oil change to access the filter easier. Blow off the Outerwears and whack the filter against the tire a few times to knock some of the dust out and throw it back on. Still seems to be doing just fine.
Old 02-22-2010, 12:18 PM
SIXSLUG's Avatar
OldDodgeOwner, I pretty much do the same thing and it still looks really clean on the inside. I think I'll get the outerwears to help keep the larger stuff out of the filter folds.
Thanks, guys!
02-22-2024 07:16 AM
Rickcher
09-02-2009 05:08 PM
Marine
113
11-06-2007 06:24 PM
Ace
10-31-2007 06:46 PM
Quick Reply: Bhaf
