best fuel/water separator??
Old 01-21-2009, 05:44 AM
smokinram99's Avatar
ive a Perma Cool fuel water separator and need a replacement element...what guys do you use? I would stay with the perma cool ones or there are better quality filter? ive the one w the drain plug....
heard many compliment on Baldwin filters too
rob
Old 01-22-2009, 01:15 PM
vrj
vrj's Avatar
I use a Raycor 4120 unit as my trucks' pre-filter unit. My filter is a 10 micron filter and the stock filter is a 2 micron filter. The Raycor filters come in various lengths/ratings and use a clear bowl with a drain port. A heater option is available if you live in very cold climates. My unit also has a primer pump and port for priming the system after filter elements are changed.
I cross referenced my filter and also purchased Baldwin and another brand which I just forgot.
Now I can get filters at almost any truck stop in America. I didn't want a special filter element that I could only buy from one shop or store.
Hope this helps.
Old 01-22-2009, 02:01 PM
shorthair's Avatar
On my WMO pump I use baldwin bf1212 filters with no real complaints.
Old 01-22-2009, 03:16 PM
CoastalDav's Avatar
RayCor SM2000 if you can find one. Best centrifigal fuel movement I've seen.
Its a small marine type with bronze colored bowl and drain on bottom. 10mc
filter if you need it.
Have not installed it on the Dodge because of the setup. If I were to change to the tank pump set up, I would install it before the fuel filter were the LP currently is without a filter. Just use it to spin out the junk. You would not believe the sand and other nastys after a few thousand miles.
Dave
Old 02-04-2009, 01:11 AM
Swarthy Dago's Avatar
Hey guys, on my 1995 I have an aftermarket spin on plumbed before the stock set up close to the block. I change the first one every 3000 mi, then the stock one every 10k or so. Where would I need to install a water/air seperator and what would be a good brand/model ? Thank you in advance.
Old 02-04-2009, 07:06 PM
Buzz'nhalfdozen's Avatar
i got a duel filter head from cummins so i could use a H2O/fuel prefilter and a fine final filter. i had to change my filter housing to a 96 spin on style and get an adapter but i now have duel filters right where my old stock one was. fits great and should extend the life of my IP.
ouchman
03-27-2006 06:22 PM
ii caan
01-28-2006 07:49 PM
chailey
07-29-2005 01:51 PM
67HotRod
06-13-2005 08:01 AM
Hoss
06-16-2003 08:51 AM
Quick Reply: best fuel/water separator??
