bent push rod
Old Feb 10, 2007 | 06:33 PM
dodgec68's Avatar
Red face bent push rod
Hey guys, yeah the problem was not my head gasket, pulled my head this morning and had everything off, went to pull all my push rods and number three exhaust would not come out. finished pulling the head and found out y. I think that someone tried adjusting the valves before and tightened number three exhaust at the wrong time started the engine bent the push rod but didn't realize what they had done.
I you have any Ideas let me know, the piston, valve and tappet all look good, anything else I should check?
thanks for all the help
Jesse
Old Feb 10, 2007 | 09:22 PM
Just check to make sure the valve is sealing, sometimes when they hit the piston they get bent. Lay the head upside down and fill the chamber with mineral spirits. If it doesn't leak into the exhaust port, put 'er back together with a new pushrod.
Old Feb 10, 2007 | 09:58 PM
dodgec68's Avatar
sweet, thanks
do you have any other ieas of what might have caused it?
thanks jesse
Old Feb 10, 2007 | 10:05 PM
mhuppertz's Avatar
Pull the lifter and check the wear pattern, and check the lobe on the cam. Make sure they look just like the others and are not pitted or scorched.
Old Feb 10, 2007 | 10:15 PM
dodgec68's Avatar
don't know if you have ever looked at the cam lifter setup on the ctd's but they have tappets lifters instead of hydraulic lifters, and to check them you have to pull the entire front off the motor and pull the lifters after you pull the cam not really a quick thing. tappet slides up and down easily and looks ok.
unless I am mistaken
Old Feb 10, 2007 | 10:19 PM
mhuppertz's Avatar
Sorry, mental head slap. I knew they were mushroom tappets...
Old Feb 10, 2007 | 10:58 PM
dodgec68's Avatar
Yeah I hate it when that happens
Old Feb 11, 2007 | 12:11 AM
Smkndzl's Avatar
the 5.9 are known to bend push tubes on high idle time engines in cold climates, valves will sieze in guides and bend push tubes.
Old Feb 11, 2007 | 07:03 AM
You can also bend 'em over-revving the engine.
Old Feb 11, 2007 | 02:40 PM
dodgec68's Avatar
bought the truck in salem,or so possible with the cold start, the owner also pulled with it so he may have over reved the motor, whatever happened it happened before i got it.
also about what rpm is red line for the cummins, stock?
Old Feb 11, 2007 | 05:59 PM
It's not a good idea to exceed 3500 RPM, that's when you run into valve float.
Old Feb 12, 2007 | 01:23 PM
dodgec68's Avatar
thanks, on my next truck I am going to put new valve springs in before I go to crazy with mods
1stGen72
Feb 2, 2009 11:51 PM
2006BLKMegacab
Jan 2, 2009 06:25 PM
rootremblay
Oct 8, 2007 08:51 PM
rootremblay
Oct 8, 2007 05:25 AM
ciscohusker
15
Feb 26, 2007 03:40 PM
