Battery Trouble
Old 01-15-2009, 09:44 AM
Barry Smith's Avatar
Battery Trouble
I replaced both batteries about a year and a half ago. Since then I've replaced the passenger side battery 3 times. I could understand one battery going bad maybe 2 but 3? All on the passenger side. Any ideas would appreciated.
Old 01-15-2009, 09:46 AM
infidel's Avatar
No real difference in charging or draw.
Think it's just a coincidence.
Old 01-15-2009, 10:25 AM
Dartmouth 12V's Avatar
Have you checked the connections to it? If there is a lot of corrosion, it might not be getting charged.
Old 01-15-2009, 01:01 PM
I appreciate the quick replys. I thought the same thing about the charging. They are Auto Zone batteries so i guess 3 bad ones aren't out of the relm of possiblity. I just couldn't think of any reason for this.
Old 01-15-2009, 01:09 PM
Also when they checked the batteries under load they were dead!
Old 01-15-2009, 06:27 PM
dozer12216's Avatar
I believe you will find a corrosion issue with a cable to pass side battery.
Sometimes a cable problem with see voltage on one battery, but all the charging goes to other as no connection between. Check all cables and connections. A swelled cable sheathing is a giveaway. JMHO
Old 01-31-2009, 09:18 PM
Dozer, the passenger side cable is corroded alittle. I didn't think about that causing a charging problem but I'd say your right. I hate to admit it because I think a new cable harness is around $180.
Old 02-01-2009, 02:16 AM
Dr. Evil's Avatar
Make your own out of some welding cable or you can buy them from here for reasonable:
www.custombatterycables.com
Dodge Ram - http://custombatterycables.com/appli.../dodge_ram.htm
They also sell everything you would need to build your own set of cables.
ridlangus123
12-30-2013 08:36 PM
jesussaves
11-07-2010 06:55 AM
EdmontonCanada
10-10-2008 11:37 AM
taildragger
38
12-19-2006 09:49 AM
planejane
08-23-2004 03:17 PM
Quick Reply: Battery Trouble
