Battery Trouble
I replaced both batteries about a year and a half ago. Since then I've replaced the passenger side battery 3 times. I could understand one battery going bad maybe 2 but 3? All on the passenger side. Any ideas would appreciated.
No real difference in charging or draw.
Think it's just a coincidence. |
Have you checked the connections to it? If there is a lot of corrosion, it might not be getting charged.
I appreciate the quick replys. I thought the same thing about the charging. They are Auto Zone batteries so i guess 3 bad ones aren't out of the relm of possiblity. I just couldn't think of any reason for this.
Also when they checked the batteries under load they were dead!
I believe you will find a corrosion issue with a cable to pass side battery.
Sometimes a cable problem with see voltage on one battery, but all the charging goes to other as no connection between. Check all cables and connections. A swelled cable sheathing is a giveaway. JMHO |
Dozer, the passenger side cable is corroded alittle. I didn't think about that causing a charging problem but I'd say your right. I hate to admit it because I think a new cable harness is around $180.
Originally Posted by Barry Smith
(Post 2371537)
www.custombatterycables.com Dodge Ram - http://custombatterycables.com/appli.../dodge_ram.htm They also sell everything you would need to build your own set of cables. |
