bad engine problems
Old 05-03-2007, 10:58 PM
fbgdiesel's Avatar
bad engine problems
WE recently installed a new timing cover because of the K.D.P, and it cracked the housing. we got everything done and went to take it for a ride and it sputters and blows a serious amount of white smoke. we cracked the fuel lines and double checked everything. its a 97 2500 12 valve diesel. towards the end of tonight it wanted to blow a little black smoke but it remaind for the most part white. any help is appreciated thanks
paul
Old 05-03-2007, 11:08 PM
torquefan's Avatar
Sounds to me like the injection pump timing slipped while putting the gear back on the pump. It's pretty common, sometimes you can fool around for hours trying to get it exactly where you want it, it's easy for it to slip while you are tightening the nut.
Old 05-03-2007, 11:10 PM
fbgdiesel's Avatar
so how exactly can we correct that?
Old 05-04-2007, 12:59 AM
Muddin_dude06's Avatar
http://dodgeram.info/tsb/1994/18-10-94a.htm
This is the procedure for correcting the problem. I as well believe that the timing slipped, it really isn't too hard to do BUT will be time consuming. On the two trucks I have done it took several tries to get the pump to stay where I wanted when popping the gear off the shaft. What helped a bunch is overshoot your desired lift by quite a bit and then rotate it the other way to go back down to where you want it, work a bunch better for me doing it this way!
Old 05-06-2007, 09:12 PM
fbgdiesel's Avatar
thanks alot guys i really appreciate it. the truck is running great
paul
DJ Turbo.
10-13-2011 09:11 PM
65fury
25
04-06-2007 08:16 AM
Buckshotram
01-09-2006 09:27 AM
C Pierce
03-21-2005 08:41 AM
doomgaze
02-06-2003 06:51 PM
Quick Reply: bad engine problems
