Anyone Try The Steering Stabilizer Kit?
Old Jan 5, 2009 | 07:35 AM
sallyman1's Avatar
i have a FARM SHOW magazine 2009 edition and on page 21 there is a kit a guy designed for 2003 newer rams to prevent death wobble and stiffen front end frame.its $209 with money back guarantee. do u think its worth it?order # is 1-866-211-1533 its made by Russel Tessier , Solid Steel Industrial Manufacturing, LTD weyburn sask canada. his phone # is in there to.it uses existing holes and supports sector shaft with a bearing.installation takes half an hour. his phone number is 306-842-4346
Old Jan 5, 2009 | 07:46 AM
RonP's Avatar
Lots and lots of posts on here about them. Many companies make them. I have one and it feels like is made the steering a little tighter. I used the one from Defiant though.
Old Jan 5, 2009 | 08:54 AM
BMH95's Avatar
I've got one too, only mine is a PSC model. They are great. You can feel it. The front end get stiffer over bumps and such, and the steering feels tighter and more responsive. I'm happy.
Old Jan 5, 2009 | 09:21 AM
sallyman1's Avatar
is it easy to install?
Old Jan 5, 2009 | 09:35 AM
BMH95's Avatar
very easy
longer post required so this line is to fill up the space
Old Jan 5, 2009 | 11:52 AM
CTD NUT's Avatar
I have the Solid Steel unit. It is about a 20 minute install if none of the bolts are seized. But don't expect it to cure DW if a loose pitman shaft is not the root cause of the DW in the first place. Regardless, it is a good mod to install as it will seriously prolong the life of the box and stiffen the frame where it counts.
Old Jan 5, 2009 | 06:33 PM
megajoltman's Avatar
I have one on my 98 easy to put on, seemed to stiffen up the front end.
Old Jan 5, 2009 | 06:40 PM
mitternocht's Avatar
I have that sector shaft brace from Canada. It is a nice unit, easy to install. It may not prevent death wobble if you have other problems, but it sure should save your steering box.
Old Jan 5, 2009 | 09:46 PM
Hayseed's Avatar
Yep it does help. I recommend the solid steel unit. Darin is a real nice guy to talk to.
Old Jan 5, 2009 | 09:47 PM
Hayseed's Avatar
Hayseed's Avatar
Hayseed's Avatar
Hayseed's Avatar
MikeMotorhead
Feb 9, 2011 08:14 AM
sallyman1
Jan 24, 2010 04:01 PM
Brian Lent
Oct 18, 2008 10:09 PM
tacook
Aug 14, 2007 01:48 PM
Mark Thomas
Dec 17, 2004 12:17 AM
