adjusting valve lash
Old 11-30-2005, 04:35 PM
Bonsai62's Avatar
I have a 95 with 130,000 miles . I ve had the truck for two years and it runs good. Don,t know if i should get the valves adjusted. Manual says every 30000, like to hear what others are doing. thanks
Old 11-30-2005, 04:51 PM
dbrick's Avatar
sounds about right. Its been a bit longer than that since my last adjustment. I probably should get it done. maybe next spring when it warms up a bit. When I do that I will go to the heavier 60# springs. I don't see a high priority in getting it done every 300000 k. You kind of gettin that feeling. There are probably others that will gasp at this
Old 11-30-2005, 05:06 PM
BBWD's Avatar
You can do it yourself:
http://dodgeram.org/tech/dsl/valve_adj/12_valve.html
#5 & 6 are a little hard to get to but with a little patience it is no big deal.
Buy a set of new valve cover gaskets while you are at it.
John (DH)
Old 11-30-2005, 05:18 PM
John Faughn's Avatar
For the cost of these engines , not doing maintance , then don't complain when you have problums, not any sooner than 30,000 and not any later than about 50,000 , I've rebuilt a lot of heads gas and some diesel becouse no valve adjustments , they get out of time with the burning and burn pie shapes out of the exhaust valves and with the diesels if they get to far out they can hit the pistons and bend a nother valve job. One of the symtems is a ruff idle hot or cold for getting out of adjustment .
Old 11-30-2005, 07:17 PM
MnTom's Avatar
John, you also forgot to mention the fact that adjusting the valves help with the fuel mileage too. Mine did. It also starts better when cold too.
Tom
Old 11-30-2005, 08:03 PM
cumminsdriver635's Avatar
Sounds like i need to adjust mine.
Eric
Old 11-30-2005, 08:05 PM
hotmopr's Avatar
I do to... I also want to swap springs while I am at it.. Any help on this task???
Old 11-30-2005, 08:12 PM
MnTom's Avatar
Sure come on over!!
Old 11-30-2005, 08:18 PM
jrs_dodge_diesel's Avatar
Check out my gallery, I took some great pics when I did my adjustment. The only difference is that I don't have a timing pin (24 valve), instead I have timing marks that I had to align by sight.
Old 11-30-2005, 08:36 PM
abbeyinc's Avatar
Hey gang,
Does anybody have the procedure and specs for doing the valve adjustment on a 1998 24v? dodgeram.org has the 12v, but not the 24v.
Time to do mine.
Old 11-30-2005, 09:35 PM
MnTom's Avatar
The procedure is the same for the 12v and the 24v.
Old 11-30-2005, 10:25 PM
Originally Posted by abbeyinc
Hey gang,
Time to do mine.
Check out my gallery. I put a real good description of the process with each photo. Plus there is a article in the Tech Facts section, only bad thing is it has no pictures.
Old 11-30-2005, 10:34 PM
Absolutey right. Only difference is a Y shaped piece of metal and an extra valve.
Old 12-01-2005, 10:42 AM
infidel's Avatar
Originally Posted by Bonsai62
I have a 95 with 130,000 miles . I ve had the truck for two years and it runs good. Don't know if i should get the valves adjusted. Manual says every 30000, like to hear what others are doing. thanks
The first two adjustments are the most important, after the engine is broken in the adjustment will change so little that it's hardly worth doing.
If I were to write out the schedule it would be more like 30-40k, 100k then every 100k after that.
VaultRam
11-18-2013 08:11 AM
Duallydog
21
04-01-2009 06:59 PM
REDNECK-WELDING
04-04-2008 06:06 PM
siebertl
09-18-2007 10:43 PM
SmokeyBear
06-07-2006 08:34 AM
Quick Reply: adjusting valve lash
