ABS light & brake light
Old 08-17-2003, 12:14 AM
azjeff's Avatar
I have intermittent dash light for the ABS & brake. I have been told that speed sensors could cause this, if that's the case where would I look for them? And also, is there one for each wheel and how is it tested to find the faulty one? It was on most of the time when I bought the truck just over a month ago, after putting on front pads, for whatever reason they have not been on as much, until this past week. Am I right withh the sensor(s) or should I be looking someplace else. Any thoughts are appreciated. Jeff
Old 08-17-2003, 09:29 AM
LHartman's Avatar
Re:ABS light & brake light
Speed sensor is on the top of the rear differential (on mine). Mine did the same thing. I changed out my front pads too, but the problem was still there. I paid around $30.00 for the sensor. Changed it out and the problem was fixed. Takes about 10 - 15 minutes, if that, to swap it.
Good luck.
Loren
Old 08-19-2003, 07:22 PM
dewclaw's Avatar
Yes , Turbowd is right, I had the same problem , replacement of the speed sensor on the rear diff fixed it . Got advice from someone else here.
Aint this site great !?
~Brett
Old 08-19-2003, 07:40 PM
Dieseldude4x4's Avatar
Just picked up my new sensor tonight. I'll see if that turns the light out.
Old 08-19-2003, 08:06 PM
azjeff's Avatar
Thanks guys, I'm pretty sure that's what I need- I just haven't picked one up yet. I'll let you know after I do. Thanks, Jeff
Old 08-20-2003, 05:35 AM
Mine was like $32 and change.
Old 08-20-2003, 06:49 PM
Well, that was $32 bucks and change down the drain. Put the new sensor on and the light is still lit. Guess it's time to get out the black tape unless I can find a dealer I can trust to hook up the computer to it and see what is wrong.
Old 08-20-2003, 07:42 PM
DarrellB's Avatar
Aren't there sensors on the front as well? :-
I don't have my manual here at work but I can check when I get home.
DB
Old 08-31-2003, 09:03 PM
SAWBUCK's Avatar
I DON'T KNOW IF THIS WILL HELP IN YOUR SITUATION BUT MY LIGHTS WERE COMEING ON ACOUPLE OF WEEKS AGO DRIVEING ME NUTS - ONE TIME I CHANGES THE STOP LIGHT FUSE AND THEY WENT OUT - NEXT TIME DIDN'T HELP.
ANY WAY IT TURNED OUT TO BE A WIRE TOUCHING THE FRAME ON MY INBED EXTENTION FOR THE TRAILER HOOKUP- NO COST AND EASY FIX THIS TIME WISH ALL WERE THAT WAY.
Old 08-04-2012, 09:57 AM
dkelsey's Avatar
My abs and brake lights in dash started coming on about 2 days ago when I backed out of my driveway, after reading several posts I think I am going to replace my brake light switch it is $11.00 dollars I'll start with the cheapest solution because I have had trouble with my brake lights staying on and having to pull up on brake pedal when I get out of the truck.
fitzydog
21
10-11-2017 12:09 PM
oldiron27
09-06-2012 11:26 AM
Joey-D
12-12-2011 12:52 PM
BigBore050
03-09-2010 11:46 PM
mr T
02-24-2007 06:42 AM
Quick Reply: ABS light & brake light
