Abs & Brake light & Dimm Headlight
Old Jul 26, 2012 | 09:22 AM
oldiron27's Avatar
Abs & brake lights come off & on ,Code read open right sensor . Replaced Rt. frt wheel hub & sensor . Still got same code , Put ohm meter on wires up to fuse box & found no breaks in wires . I replaced the rear sensor a year ago , also noticed speedometer on the take off sometimes does not work until I get going for a ways . Also the right head light is very dim, replaced the bulb , same, replaced head light switch , same , put in a different dimmer switch , no change , then I checked all the grounds , loosened & retightened , no change .My truck has single head lights & fog lamps, no daytime runin lamps . Truck is a 1999 , 3500 ,diesel , But rearend is a 1994
Old Jul 26, 2012 | 09:39 AM
infidel's Avatar
I know the '98.5 truck's speedo reads off of both the tranny (or transfer case if 4wd) and the rear end.
Can't remember which way it goes but one sensor reads for under 30 mph, the other for faster.
Could be since you have a '94 rear end the sensors aren't communicating with each other correctly.
Old Jul 27, 2012 | 08:44 AM
oldiron27's Avatar
speed-o-meter
Thankx for the imfo Infidel, I'll check out the sensors , have a good one !
Old Sep 5, 2012 | 11:50 AM
totalloser's Avatar
A partially blown fuse can cause the headlight problem.
The rear diff speedo sensor reads (if I remember right) the teeth on the ring dear of the differential like a reluctor. Above x mph (I thought it was 15mph) it reads the transmission sensor. I'd take another look at the rear diff wiring. Some cheepo scanners goof on which sensor is iffy, or the computer may get different readings and point the finger at the good sensor instead of the bad sensor.
I don't *think* the front wheel sensors affect the speedo at all, but the computer compares the various sensors to operate and verify function of the abs system. It might have goofed identifying the RF sensor.
Old Sep 6, 2012 | 11:26 AM
Redlinear's Avatar
Is your right front hub going bad?
Is the replacement sensor in the right front hub at the proper depth to read off of the reluctor ring inside of the hub?
fitzydog
21
Oct 11, 2017 12:09 PM
Joey-D
Dec 12, 2011 12:52 PM
BigBore050
Mar 9, 2010 11:46 PM
polaris800sp
Apr 7, 2009 10:08 AM
mr T
Feb 24, 2007 06:42 AM
