92 major wiring issue
Old 07-18-2011, 02:07 PM
chevelleriley's Avatar
Exclamation 92 major wiring issue
my headlights on my truck wont turn off and my speedometer works wen it is cold oldside but wen it gets warm out it works once ina while, i have a new headlight switch an it didnt fix the headlight problem, but i noticed if i slam the door there turn off for a second, im thinking it is a body ground issue, where are the body grounds located on these trucks?
Old 07-18-2011, 08:35 PM
Onemoparnut's Avatar
The one that causes a lot of trouble is from the battery to the radiator support.
Old 07-18-2011, 09:18 PM
i actually just tryed that tonight and its still doin the same thing sadly
Old 07-20-2011, 08:38 PM
LABBINSKI's Avatar
92 wiring issues
Going through the same gremlins right now the speedo should be a seperate issue all together you may have a bad vehicle speed sensor pull it off and check to see how easy it spins mine did the same thing when cold worked fine when warmed it lost all continuity replaced with oe part not aftermarket as they do not hold up no as far as head light not turning off I would check all grounds on the truck as it will be with that circuit only or you could have a chaffed wire keeping power going to it even when off hope some of this helps Brian
Old 07-20-2011, 10:36 PM
GIT-R-DONE's Avatar
I would check the back of the headlight switch again to make sure no pins are bent over and it is connected properly. It kinda does sound like a ground issue too, but something is sending power to it, thats what you have to find.
My headlight issues were with a ground....and a bad switch combined, so it could be a few things going on.
Old 07-24-2011, 10:41 PM
RuralCruiser007's Avatar
Was this truck originally from Canada? It is notorious for the DRL module to fail and you headlights will not turn off. Look on the passenger fender skirt for a black box with one connector with about 8 wires going into it.
Your headlights will still work with it unplugged, but your high beam indicator will not work.
Old 07-24-2011, 11:17 PM
GIT-R-DONE's Avatar
Can you post up a pic of this module ?
Old 07-24-2011, 11:22 PM
I can tomorrow. It is right underneath the windshield washer bottle held on with two phillips screws.
Old 07-25-2011, 04:52 PM
The little black box under the washer bottle is the DRL module.
Old 07-26-2011, 08:02 PM
Dlowkes7's Avatar
i dont think i have ever seen one of those on my truck from mexico,lol
Old 07-26-2011, 09:02 PM
GIT-R-DONE's Avatar
I dont know that I have ever seen one either. What does DRL stand for ?
Old 07-26-2011, 09:29 PM
DRL means daytime running lights. Standard equipment in Canada I think
Old 08-07-2011, 11:23 AM
oh im gona go check that right now, but in case thats not the problem where are the grounds located in the truck? i already cleaned the one goin to the radiator bracket
Old 08-07-2011, 12:33 PM
GIT-R-DONE's Avatar
Not saying that this doesnt exist, I have just never seen one with them on is all. Learn something new everyday !
06RAM2500
02-24-2013 09:00 AM
tuff dodge
04-26-2010 11:59 AM
jasonram2500
09-01-2009 09:19 AM
mullishacrew
08-03-2008 05:43 AM
SSweeney
07-16-2006 07:35 PM
Quick Reply: 92 major wiring issue
