3000 gsk, do I got it
Was thinking of getting 3000 gsk for a while now but thought I should see what it had before I spent my hard earned money. Well I left it in first and to my surprise truck went all the way to 3200. It didnt run great at 3200 but it en fine at 3000. Do I already have springs or can this be done with stock equipment. thanks
My truck does not have it
I can tell because when i run it hard it rather defuels at about 2400 rpms at fifth gear, yet it does fuel hard on all other gears to about 2800-3000 rpms, after that it just seems to bog down.. IF you have any of these syptoms, probably no GSK..
TX
TX
I got an auto so I dont know about 4th I would be going way too fast by the time I got to 3000. Maybe I'll try it in second toay on the highway and see if I get the same results
put it in third gear, then hammer down...if it falls on its nose above 24-2500, you don't have them. It will slowly work it's way up to the redline if it doesn't have the springs.
If it wraps right up with a load on the engine, you have the springs.
Chris
Chris
fishin fever
03-13-2006 06:46 PM
Dusty 96
11-05-2002 01:45 AM
