2006 tow mirrow problem
Old 11-02-2008, 07:16 PM
vaskeet's Avatar
the drivers side tow mirrow does not stop in the detent possition it seems like the mirrow has a larger space between the two peices where they pivot. Has amyone taken them apart and what is on the inside at the pivot point? It seems like a cap on the bottom of the pivot point is there a bolt or a screw there I dont have power mirrows Thanks Randy
Old 11-10-2008, 11:04 PM
stackx2's Avatar
maybe its missing the moutain dew can
Old 11-11-2008, 10:05 AM
Foxborough's Avatar
Sometime this summer someone wrote up a procedure on disassembling the mirror and fixing the detent part. Sorry for the lack of more information. It sure can't hurt to try to fix it first, you can't break something that's already broke . The worst you will need to do is buy a new or used one later. I found two post that may help.
https://www.dieseltruckresource.com/...ght=tow+mirror
Old 11-11-2008, 03:01 PM
hoffdog's Avatar
i have the same problem on my 03 on the passenger side it doesnt lock into position and there is a larger gap like you described i would also like to know how to fix it.
lawnmaniac883
05-18-2007 08:50 AM
DanTana
03-06-2006 05:56 AM
Cold Diesel
10-26-2004 07:37 PM
J&L
05-15-2004 05:04 PM
Quick Reply: 2006 tow mirrow problem
