12 valve to chevy swap
Old 12-08-2011, 09:15 PM
jayhoo's Avatar
i am thinking about doing a 12 valve swap in to my 1996 chevy it has a nv 4500 i was thinking 94-98 cummins .they have t.p.s do i need to use it?.
i could use some help if some one has done it befor .
Old 12-08-2011, 10:31 PM
torquefan's Avatar
Sounds like a good swap. On the 12 valves, only the autos came with a TPS. You should be fine without it using an NV4500. Be aware, I think the NV4500 the Chevs used was different than the one Dodge used. Smaller input shaft on the Chev, and different bolt spacing to the bell housing.
Old 12-09-2011, 08:12 AM
patdaly's Avatar
Actually, 96 was the first year they used common cases, so you are good there. Minimum you will need input shaft.
Easy enough swap, 2WD or 4?
Check out Destroked.com and 4btswaps.com.
Old 12-09-2011, 11:37 PM
jayhoo's Avatar
its a 4x4 crew cab
SRobertson
02-07-2012 12:38 AM
2 valve
03-06-2011 11:35 PM
racinrex
06-04-2009 12:54 AM
rebel5422
04-11-2008 04:41 PM
95black2615
19
05-24-2006 11:05 AM
Quick Reply: 12 valve to chevy swap
