12 valve #8 plate
Old Aug 12, 2006 | 01:32 PM
cluckmaster's Avatar
12 valve #8 plate
I've got a #8 plate, and I want to slide it full forward. It's already as far forward as the guide that came with the plate allows, but the holes on the plate itself have plenty of room left to move. Can I just slide the plate as far forward as I can using the holes in the plate, or do I have to utilize the TST guide? Thanks! -Josh
Old Aug 12, 2006 | 01:46 PM
signature600's Avatar
The guide is to keep the plate in there "square" If you shove it forward, you can just max out the holes in both sides to keep it square
Slide that sucker...but make sure to check where the governor arm rides on the plate after you do!
Chris
Old Aug 12, 2006 | 05:21 PM
Teddy Bear's Avatar
While you're in there go ahead and take the plate out and make a 100 or a 0 out of it My truck had a #8 in it when i bought it but we put a 0 in there and it really woke it up
Old Aug 12, 2006 | 06:52 PM
berner's Avatar
Got guages? My truck ran fairly hot with an 8 plate slid about 1/16".
Old Aug 13, 2006 | 03:14 AM
Teddy Bear's Avatar
With my #8 plate full forward i never got it over 1300*
Old Aug 13, 2006 | 04:53 AM
monsterB's Avatar
grind it!
slide it!
give about 1/4in. clearance from the front and have fun!
Old Aug 13, 2006 | 08:04 AM
berner's Avatar
I had no guages with the #8 and a 3K gov kit. It was a real eye opener to see 1400* at the top end of 3rd gear when I finally installed a pyro.
It all boils down to how much of a gambler you are.
Old Aug 13, 2006 | 03:35 PM
yeah- got Diprocol Optix gauges. Installing them now too! We slid it some, just to see how much difference it makes, and then we'll go back and make changes. Thanks!
What's the difference between the 10 and 0 plate? I've seen how to grind the 100 from a #10.
West Coast
Jul 1, 2007 02:32 PM
plow
Jul 20, 2005 08:40 PM
Rockcrawler
Jun 23, 2005 11:40 AM
banks twinram
Feb 5, 2005 10:38 AM
