03/04 Waste gate Mods
Old 05-07-2007, 05:01 PM
azdodge's Avatar
Does anyone know how to mod the waste gate pn 03/04 5.9l cummins in order to use the boost fooler device???
Old 05-07-2007, 05:48 PM
Rob C's Avatar
since those years use a mechanical wastegate, and the boost foolers are for the electrically controlled wastegates, I don't think you can.
Old 05-07-2007, 07:19 PM
cjones42's Avatar
TST sell a Boost elbow that lets you restrict your waste-gate and you boost will be up. You can adjust how much max boost you get with a allen wrench.I just did it to mine.
http://www.tstproducts.com/index.asp...PROD&ProdID=33
Old 05-08-2007, 07:11 AM
MikeyB's Avatar
You can also find them on ebay. Do a search for 'boost elbow'.
MikeyB
Old 05-08-2007, 08:42 AM
azdodge's Avatar
According to the boost fooler, the 03/04 has to modified so obviously they realize the need in order to use their unit.
Old 05-08-2007, 10:07 AM
DTR 1st Sergeant
soulezoo's Avatar
I did this mod myself. The outlet end of the elbow is a little longer than the stock elbow and difficult to put on without taking stuff apart. You can remove the stock elbow easy enough reaching from the bottom of the truck. If you drill a hole through the top of the elbow from the treaded side of the elbow as your guide and taking care not to "ream" it out, I think it was a 7/32 drill I used the tap with a 1/4" tap and use a 1/4"x1/2" set screw, you can adjust the airflow from full to nothing or anything in between. Takes no more than 1/2 hour for the whole project. Be sure to use loctite on the set screw when you have it where you want it.
Old 05-08-2007, 10:10 AM
DTR 1st Sergeant
soulezoo's Avatar
And I forgot to mention--- I already had the tap and drill on hand so the only expense was the set screw at less than a buck. And a few cents worth of loctite that I already had too...
Old 05-08-2007, 08:23 PM
triplenickel's Avatar
Pull the elbow and plug the hole.
nasty01cummims
04-23-2009 07:36 PM
azdodge
22
05-14-2007 05:32 AM
whiteknight
17
01-08-2003 10:38 PM
ox
01-08-2003 08:41 PM
Quick Reply: 03/04 Waste gate Mods
