03/04 Waste gate Mods
TST sell a Boost elbow that lets you restrict your waste-gate and you boost will be up. You can adjust how much max boost you get with a allen wrench.I just did it to mine.
http://www.tstproducts.com/index.asp...PROD&ProdID=33
I did this mod myself. The outlet end of the elbow is a little longer than the stock elbow and difficult to put on without taking stuff apart. You can remove the stock elbow easy enough reaching from the bottom of the truck. If you drill a hole through the top of the elbow from the treaded side of the elbow as your guide and taking care not to "ream" it out, I think it was a 7/32 drill I used the tap with a 1/4" tap and use a 1/4"x1/2" set screw, you can adjust the airflow from full to nothing or anything in between. Takes no more than 1/2 hour for the whole project. Be sure to use loctite on the set screw when you have it where you want it.
nasty01cummims
Apr 23, 2009 07:36 PM
azdodge
22
May 14, 2007 05:32 AM
whiteknight
17
Jan 8, 2003 10:38 PM
