U joints
Old Apr 14, 2006 | 05:30 PM
03 ant a hemi's Avatar
U joints
Does any one know any part numbers for u joints on a 2003 Ram 4x4 diesel. My old ones are toast, drive shaft is out of the truck, the ones I bought are two small. If any one has the after market part numbers for any NAPA, ACDelco etc be appreiciated. Thanks
Old Apr 14, 2006 | 06:18 PM
djgaston's Avatar
Front driveshaft? Rear driveshaft?
Just go to www.napaparts.com and you can see all of the part numbers. Enter in your truck info and search. They sell Precision U joints (they start with PUJ in the part numbers) and that is what I run.
Old Apr 14, 2006 | 06:29 PM
PourinDiesel's Avatar
6 speed or auto?
Old Apr 14, 2006 | 07:20 PM
Sorry rear drive shaft, and auto.
The local NAPA store gave me some UJN2-0053 u joints. Of course they are incorrect.
Old Apr 14, 2006 | 07:38 PM
Go to www.rockauto.com
They stock ALL U joints for our trucks and they are cheap too!
Rock Auto carries Precision and AC Delco.
***Not affiliated with Rockauto in anyway (other than buying from them!)
Old Apr 15, 2006 | 08:16 AM
one8upcb's Avatar
Precision 295 for auto and rear drive shaft
Old Apr 15, 2006 | 11:19 AM
Thanks guys. I got the precsions now. Buggered one up waiting for the third one to be delivered.
Old Jun 13, 2010 | 12:52 PM
big-c's Avatar
would these fit a 03 with 6 speed trans
Old Jun 13, 2010 | 03:00 PM
Rednax's Avatar
http://quad4x4.com/Dodge%20Drive%20Shaft.htm
Old Jun 13, 2010 | 04:06 PM
1985cucv's Avatar
they can be a pain to get out! cut out the middle and press each cap out one by one i know because i just did mine!
Old Jun 13, 2010 | 06:16 PM
Bark's Avatar
This was a post that I copied a couple of years ago for my 03:
""If you want to install some good greasable joints go to napa and ask for a 351A precision U joint.
Its the same part for all 3 rear u joints on the 6 speed regardless of single or dual wheel status.""
I have not changed mine so I cant say for certain that the above info is correct. Maybe somebody else can say for certain about the part number.
Old Jun 13, 2010 | 07:34 PM
Jeff in TD's Avatar
I heated mine a bit, and pressed them out with a ball joint press. Indeed they can be a bugger.
kprc51
Jun 14, 2007 06:27 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
Dynocon
Mar 5, 2005 06:24 PM
