Clicking sound from 0-40mph?
Old Jun 11, 2010 | 02:03 PM
WEATHERBY460's Avatar
When I let off the gas, i hear a ticking sound when slowing down. It kinda sounds like its doing it every revolution of a tire, but cant see anything wrong with the tires? Any gut feelings?
Old Jun 11, 2010 | 02:09 PM
klx650a2's Avatar
As silly as it sounds, I've had the same thing and it was a rock stuck in the tread.
Check your u joints also.
Old Jun 11, 2010 | 02:50 PM
marathon's Avatar
U-joint
Old Jun 12, 2010 | 04:36 AM
sticky's Avatar
Had the same issue twice. Both times it was the front axle u-joints.
Old Jun 12, 2010 | 10:12 AM
i already had one bad on the rear, dealer fixed under warrenty, what does this usually cost to repair?
Thanks
Old Jun 12, 2010 | 10:41 AM
.boB's Avatar
Check your wheel weights. The type that clamp on to the edge of the rim sometimes come loose, and slide back and forth with each tire rotation.
That happened to me with a '84 T-Bird. Drove me nuts trying to figure that one out.
Old Jun 13, 2010 | 07:40 PM
Jeff in TD's Avatar
Thanks
If I recall correctly, a shop wanted like $250 to do a rear drive shaft U joint. I had the time, so I just did it myself.
If it ticks mostly while turning, it is likely a front axle U joint, and repair is likely to be quite a bit more since removing the wheel bearing can be a bugger.
This thread has an execllent write up of front axle removal for ball joint removal (with photos).
https://www.dieseltruckresource.com/...ght=ball+joint
P.S. 460 Weatherby- neat cartridge. I've always wanted one. What for, I don't know.
admin
20
Apr 1, 2020 11:20 AM
02ctd4now
Feb 25, 2017 07:35 AM
whosdunit
Feb 10, 2010 10:03 PM
Swarthy Dago
Jul 22, 2009 10:28 PM
hoghead
Jan 14, 2007 06:45 PM
