TXDTR #8 Forum for the Texas chapter #8
TX DTR #8 - September thread
Old Oct 28, 2009 | 02:28 AM
  #286
TexasCTD's Avatar
So Justin I assume you found a house to buy? OR sold your current one? OR both? Where are you moving for sure, if you know yet?
Old Oct 28, 2009 | 08:52 AM
  #287
AggieJustin's Avatar
Well, we've sold the current one. And we've found one we want to buy, just waiting on the other party. They told their realtor they were a month or so behind on their mortgage, but we found out last week after we put in an offer that their lender started the foreclosure paperwork already. So the realtors are trying to get that turned around and hopefully get it moved into a short sale for us. So right now we're just waiting, but we know we'll be out of here on 11/20.
Old Oct 28, 2009 | 09:08 AM
  #288
XLR8R's Avatar
Hope they expedite the closing for you, Justin!
We're in the ironic position of being homeless homeowners - moved out of the old place and now waiting for the sellers to vacate our property in Denison...
Old Oct 28, 2009 | 09:09 AM
  #289
03RAMBUNCTIOUS's Avatar
I watch wind blow...
update, Turbo went in, and the ol Dodge feels like a rocket ship now..
so far so good, now just need to adjust the wastegate a pinch to go from 31psi to about 40 ish. Now do I make the rod longer or shorter on the WG to increase boost?
I figured it was going to be a 2 hour job... not the case, had trouble with water lines, clocking the turbo and oil return line. there is no way I could do the fab work that some of y'all fellars do. I am to impatient.
Max
Old Oct 28, 2009 | 09:35 AM
  #290
RowJ's Avatar
Originally Posted by 03RAMBUNCTIOUS
... Now do I make the rod longer or shorter on the WG to increase boost? Max
Way to go Max! Sounds like it solved your sluggishness problem?
Shorter Rod = Higher Opening Pressure
Longer Rod = Lower Opening Pressure
Think you told me but can't remember... where is new house?
Good that the government extended the timeframe on tax credit for 1st time buyers, Huh?
I'm assuming you qualify (present house was Andreas)? Wonder how that works...now that your married??
RJ
Old Oct 28, 2009 | 09:47 AM
  #291
RJ
thanx RJ, it seems to feel really good ( heck I may start giving Tyler mod advice), I think after the WG gets adjusted everything will be A OK I am really happy so far.
that WG may be a PITA to get to and adjust though.
PS, congrats Justin, When I get ready for house hunting I imagine it will be a nightmare. I like my space..
Old Oct 28, 2009 | 09:48 AM
  #292
RowJ's Avatar
Mike
Found out that glass crushing plant (where your stuff is stored) in on the grounds of the new Cardinal Glass Plant.
Interesting fact - The machines that make the glass are so expensive to shut down and restart later on, that the just keep making it...... and crushing it..... and recycling it, till sold!!
Sounds crazy, huh?
RJ
Old Oct 28, 2009 | 09:55 AM
  #293
RowJ's Avatar
"That's a fact...Jack"!
Surprised it's not set at at least 40 psi??
One trick I've used is disconnect WG air tube at turbo and insert compressed air supply into it, to take pressure off the rod.
Then you can easily slip the rod end off (and back on) the actuator arm (on turbo). Then just turn the rod end in. But snap ring is a pain!
And helps a lot if you have tiny hands!
RJ
Old Oct 28, 2009 | 10:43 AM
  #294
I really can't figure out why the banks want to screw around so long with approvals and paperwork on some of these. You would think that if someone is offering money that would take care of a bad note, they would jump at the chance. But we've been told by a number of people that the banks are in no real hurry to do anything.
The new place is in Shady Shores, close to Lake Lewisville east of I-35E. No tax credit for me. I became a homeowner the day we got married. But the buyers of our house are getting it, which is why we're out as of 11/20.
That's our issue. We've found a lot of nice houses, just not that many with a little bit of space around it. I'm tired of having only a small driveway and a small garage to park in. I need room for a few toys so I don't have to pay to store them or keep them all 3 hours from here.
Old Oct 28, 2009 | 11:46 AM
  #295
elirandolph's Avatar
Max
Glad to hear that you are happy with your truck again!
Old Oct 28, 2009 | 01:19 PM
  #296
93-12Smoke's Avatar
I know what ya mean. The wife has been pushing for a house, found one with a little land and a 30x30 shop already on it. Put in a bid only to find out we were out bid by someone who bid more than 10,000.00 over asking. Or so the realator says.
Old Oct 28, 2009 | 04:35 PM
  #297
RJ
the threaded rod arm has two nuts backed into each other. so I just need to get a wrench into there, It was set at the factory @ 35psi. but I think I turned the nuts the wrong way on the rod(longer) when I installed it.
So now I get to monkey around under there and try to get it fixed up.
I also had to jerry rig some clear 7/8th ID tubing on the oil return line. and if ya'll did not know there is quite a bit of oil that flows thru the turbo, I do not know GPM but its a hefty flow.
trying to source some tubing now.
Max
Old Oct 28, 2009 | 08:51 PM
  #298
Austin'sDodge's Avatar
Exclamation
Justin, good luck on your home purchase. Don't want to rain on your parade but these short sale situations can take months. Especially if its through one of the majors (Citi,Bank of America,Etc....) Good luck if its through one of them because it will probably take upwards of 6months. Hopefully you have a good agent that will help expedite things along.
Old Oct 29, 2009 | 09:28 AM
  #299
That's what we've been hearing. It just doesn't make any sense to me. You would think that if someone were offering to give money to cover a note that wasn't being paid, they would jump at the chance. Maybe that's why the banks needed a bailout. We saw another house a few months back that was in short sale as well. It had 1 offer pending and 4 more offers lined up behind it. They said the bank was taking around 3 months to approve or reject each offer.
Not sure who is holding the mortgage right now. Their original mortgage was with DHI, which is the mortgage company for D.R. Horton Homes. Didn't see that it was ever re-financed, so it might still be with them. Our realtor has been working with the other realtor to try and get the lender everything they need to hopefully move this process along a little faster.
Old Oct 29, 2009 | 10:37 AM
  #300
XLR8R's Avatar
Mike
Sounds crazy, huh?
RJ
Yeah I know - told you the last time you were at the shop...
I just hope they don't dump the wrong box van!
