TXDTR #8 Forum for the Texas chapter #8
View Poll Results: When Will You Get To The Ranch?
Friday Night Only
10.00%
Saturday and Saturday Night
10.00%
Saturday Only
30.00%
Friday Night and Saturday night
50.00%
Voters: 10. You may not vote on this poll
NT #8: May Meet
Old Apr 28, 2008 | 01:23 PM
  #136
RowJ's Avatar
Originally Posted by XLR8R
Rowland, are you using shielded clamps?
They're designed for the soft silicone hose - it's the only kind we use... what size do you need?
Didn't know there was such a thing... oh the ones with rubber liners?
My best guess at hose OD is 3/8"??
String ties wouldn't hold the hose on at 65+psi, so went to band clamps!
RJ
Old Apr 28, 2008 | 01:34 PM
  #137
XLR8R's Avatar
No, they have an internal SS band that keeps the thread slots from cutting into the silicone. The best ones are also constant-tension types (since silicone shrinks when heated), but not necessary in diameters less than 2" and sub-100psi pressures IMO.
I'll bring some appropriately-sized shielded SS clamps with me - that should solve your problem.
Old Apr 28, 2008 | 01:51 PM
  #138
AggieJustin's Avatar
Originally Posted by crobtex
Good, see you Friday.
If they have them, injector o-rings and washers. Also, o-rings for the injector tubes. No biggie, but if your going...............
Will do. I'm getting some o-rings for the connector tubes as well. Going to pull my #5 and see if I can figure out where the leak is coming from.
Old Apr 28, 2008 | 01:54 PM
  #139
RowJ's Avatar
Thanks but not sure that will solve!
It's the outside edge of my clamps that cuts into hose. Did not know Silicon shrinks...maybe I've been over tightening? I assumed the hose was balloning a bit under pressure and the clamp edge was digging into it?
RJ
Old Apr 28, 2008 | 04:23 PM
  #140
bnold's Avatar
I should be there around 2-3ish
Old Apr 28, 2008 | 08:41 PM
  #141
03RAMBUNCTIOUS's Avatar
I watch wind blow...
i wish my friends would plan there events around my diesel GTG's.... so my plans are up in the air once again.
Old Apr 28, 2008 | 10:15 PM
  #142
crobtex's Avatar
It looks like we're in for some good weather (as of today). This is for Dallas and it'll be a little cooler at The Ranch. You guys that are sleeping out need to bring plenty of covers.
Also, if it rains Friday, be sure to park on the road surfaces until it dries out some.
Fri
5/2
79°
61°
Sat
5/3
78°
55°
Sun
5/4
70s
50s
Mon
5/5
70s
50s
Old Apr 28, 2008 | 10:55 PM
  #143
XLR8R's Avatar
I'm bringing your engine AND your intake!
Old Apr 29, 2008 | 02:03 PM
  #144
13FOX's Avatar
Got a couple of Dieselram.com guys coming as well. Charlie I'll be there friday night. Just depends on how long it takes the SGM to get done with his Friday speeches. Make sure somebody brings some axes and chainsaws. That wood is dry enough to burn. Mare sure you guys leave me a spot to back the trailer in so I can get it unloaded or whereever you what to put it. I've got probably 100+ logs anywhere from 4" to 14" in size and rough 4' to 15' long. I'm leaving late IOT not be in the middle of Dallas rush hour with a load of logs.
I could also bring up some burgers from the Commisary if you like. Meat is really good and half the cost of the economy. Let me know. I lost my vioce some please email me back. Hopelyfully I can talk by Friday.
Old Apr 29, 2008 | 02:19 PM
  #145
crobtex's Avatar
My chainsaw is worn out and don't won't to start, but I do have an axe. We'll unload it in the far back corner of the back fence line.
Do what you can to miss Dallas rush hour. It ain't purdy and it ain't fun.
If it's not too much trouble, you might bring a few burgers. We may have to add it to the chili beans to make it go far enough.
I'll email or call you later. Just remembered it, sorry I missed your call the other day. We were in the process of recovering my wifes stolen van and I forgot to call back.
Old Apr 29, 2008 | 02:26 PM
  #146
bnold's Avatar
Sweeeeet! Engine work out? or lost cause???
Old Apr 29, 2008 | 04:00 PM
  #147
bigredBCS's Avatar
if I can make it out, I'll bring the big boy saw to cut some stuff Charlie!
Old Apr 29, 2008 | 05:52 PM
  #148
crobtex's Avatar
That's right, you're in the business of destroying trees!
Old Apr 29, 2008 | 06:49 PM
  #149
That's perfect sleeping weather...I was worried I might have to use the fan already.
Does this mean you found it?
I didn't see any vehicles towing south (surprisingly) on my way to Giddings Friday.
Old Apr 29, 2008 | 07:39 PM
  #150
crobtex's Avatar
Thanks for looking. Must have been a slow week for "El Mexico Transport".
The van is in the shop now. Car lot in Balch Springs bought it for junk and when they got it back, the owner said "Uh-Oh", this thing was stolen. Anyway, he called and we went and got it. A lot more to the story that I'll tell you later.
