Wiring problem?
Old Sep 10, 2009 | 03:50 PM
BMH95's Avatar
Wiring problem?
I get no passenger side blinker / brake signal out of either of the trailer connections on my '05. The driver's side works fine, but I get nothing from either the 4 pin under the bumper or the 7 pin in the bumper. This is a factory tow package with totally stock wiring. I do get running lights on that side.
Where do I start? The tail light on the truck all works correctly.
Thoughts?
Old Sep 10, 2009 | 04:09 PM
BearKiller's Avatar
It's probably not the answer you wanted, but I totally distrust any factory-supplied "towing package".
I do my own wiring and go straight to the source for all the functions and never have a trailer/truck wiring problem.
The ones that use those handy "plug and play" pig-tail connectors and trailer-tow packages are forever having problems; a few will jump in and say they never have any problems, but I see plenty.
I recommend you ignore the wiring you have and start over from the beginning as if the truck had no trailer connections whatsoever; do it right and it will never have to be worked on again.
One other thing :
Wire the trailer markers completely independent of the trucks lighting system; if you can turn ON the trailer lights with the trucks head-light switch, even if relay powered, sooner or later it will cause you grief.
Old Sep 10, 2009 | 04:38 PM
BMH95's Avatar
I'll look into the whole wiring system when I have time, but I just noticed this today, and I'm leaving at zero dark hundred tomorrow morning on a banzai 1400 mile trip with a little trailer. Any thoughts on where to look tonight? I still have to do all the other prep work before this too, and I'll need my sleep so I'm not unsafe.
Old Sep 10, 2009 | 04:49 PM
Colo_River_Ram's Avatar
With age comes the cage
Thoughts?
There is a separate fuse for the trailers blinkers and running light just look in your manual to find them..
Check the trailer light function as well things might be cross wired which is what blew the fuse to begin with..
Hope this helps
Old Sep 10, 2009 | 09:02 PM
SilentTrouble's Avatar
Fuse, fuse, fuse.
Had this problem after i bought my truck couple weeks ago in the main box under the hood the freekin running light fuse WASNT EVEN THERE! Put one in and BINGO worked fine seperate fuses under the hood on teh 07 2500 for each light function
Old Sep 10, 2009 | 10:13 PM
BMH95's Avatar
fuse
* beats head with hammer *
thx
Old Sep 12, 2009 | 12:44 PM
Kevin B's Avatar
Which fuse gave you the problem?
Old Sep 12, 2009 | 01:25 PM
Totallyrad's Avatar
What the others have said, fuses under the hood. It takes one of the tiny ones. You can buy an assortment for about $5 at most auto parts stores. Something I learned from the U-haul man working on mine, you can use a test light on the backs of the fuses so you don't have to pull each one if the labeling is missing or unreadable. Ground the test light and touch each side of the fuse with the probe. When you find one that won't light on either side of the fuse, start there.
Old Sep 19, 2009 | 11:43 PM
BMH95's Avatar
It was # 47, I think. Right trailer blinker.
Old Sep 20, 2009 | 12:25 PM
Totallyrad's Avatar
Cool! So problem solved?
wyododge
Jan 13, 2009 02:25 AM
Evildiesel
Jul 2, 2006 06:39 PM
charcoal600
Apr 30, 2005 02:34 PM
jeffket
Jun 12, 2004 11:07 PM
Caincando1
Feb 23, 2004 03:52 PM
