Wiring Aux. Brake Lights
I am hooking up aux. brake lights in the bumper of my truck and it looks like the easiest place to wire in would be the 7 pin harness. Which wires are for brakes only(don't want directionals) and ground? Thanks.
Mike
Mike
Look in the harness for a single deaded ended wire marked something like CHMSL (center high mounted stop lamp) close to where the harness leaves the frame at rear, this is where they run the wire to be used when one puts a topper on and needs the high mounted stop light for it, with this wire you will need to run your own ground. Might stop by your dealer or a dealer and see if they will show you where it is .
Mike
Posted the pics here - https://www.dieseltruckresource.com/...18#post1853718
Doj Dewd
Sep 21, 2011 03:14 PM
SD-Dave
Jan 22, 2010 02:57 PM
proudpapa97
May 4, 2008 06:50 PM
Huntindad
Jul 9, 2006 09:34 AM
Blast54
Nov 2, 2003 01:46 AM
