Wired to charge?
Old Mar 9, 2003 | 01:00 PM
mic646's Avatar
Wired to charge?
On our trucks with the factory tow group are they already wired to charge the RV batteries when hooked to the truck?
Old Mar 9, 2003 | 01:56 PM
P Kennedy's Avatar
Re:Wired to charge?
Yes with the factory tow group the plug on the rear of your truck has a always HOT line coming out for your trailer battery. The diagram of the plug wires is right on the plug cap. PK
Old Mar 9, 2003 | 02:27 PM
Thomas's Avatar
Re:Wired to charge?
And it's also wired to discharge the truck batteries when the engine is off and the RV batteries are being used. The RV batteries are not isolated from the Ram's batteries.
Old Mar 9, 2003 | 07:05 PM
P Kennedy's Avatar
Re:Wired to charge?
If used properly for the purpose intended it works just fine which is to charge the trailer battery while travelling down the road. If the trailer cord is left plugged in after travelling all day and you stop for the night to sleep everything will be ok, if you use the trailer power extensively after stopping then unplug the cord and plug back in the next day when travelling. This way battery is always fresh when you stop.PK
Old Mar 9, 2003 | 07:34 PM
FiverBob's Avatar
Re:Wired to charge?
[quote author=Thomas link=board=11;threadid=12008;start=0#113601 date=1047241674]<br>And it's also wired to discharge the truck batteries when the engine is off and the RV batteries are being used. The RV batteries are not isolated from the Ram's batteries.<br>[/quote]<br><br>Unless you install a battery isolator - - a $20 relay available from most any RV service center.
Old Mar 11, 2003 | 06:37 PM
Kimrey's Avatar
Re:Wired to charge?
On my factory tow package I don't have power unless the ignition is turned on. Go figure :
Old Mar 11, 2003 | 08:51 PM
FiverBob's Avatar
Re:Wired to charge?
[quote author=Kimrey link=board=11;threadid=12008;start=0#114640 date=1047429457]<br>On my factory tow package I don't have power unless the ignition is turned on. Go figure :<br>[/quote]<br><br>Interesting - - my 2000 had an isolation relay in it. Bought it used. Do not know if it was factory or someone put it in before I ended up with it.
Old Mar 11, 2003 | 08:55 PM
Marine's Avatar
Veteran: Marine Corp
Re:Wired to charge?
[quote author=Kimrey link=board=11;threadid=12008;start=0#114640 date=1047429457]<br>On my factory tow package I don't have power unless the ignition is turned on. Go figure :<br>[/quote]<br><br>I think this is a good idea. Only charging when you are running down the road.<br><br>Mike
Old Mar 12, 2003 | 10:09 AM
wheezer's Avatar
Re:Wired to charge?
My old PSD was hot only with the ignition on.
Old Mar 12, 2003 | 11:13 AM
GrandpasRam's Avatar
Re:Wired to charge?
Same with my old '99; haven't had a chance to test with the new truck yet.
Old Mar 12, 2003 | 12:57 PM
FiverBob's Avatar
Re:Wired to charge?
[quote author=GrandpasRam link=board=11;threadid=12008;start=0#114986 date=1047489198]<br>Same with my old '99; haven't had a chance to test with the new truck yet.<br>[/quote]<br><br>The new one is hot all the time unless you have installed an isolator.
Travs94Ram
Jun 16, 2008 05:05 PM
kd460
Jun 23, 2004 04:35 AM
CumminAtYa
Jan 22, 2004 03:13 PM
DynamicalyUnstable
Jan 20, 2004 02:17 PM
rshelton88
Jun 10, 2003 09:55 AM
