winnebego disc brakes
Old Jun 7, 2009 | 01:48 PM
DieselDodd's Avatar
I have a 96 winnebego 32RQ DP motorhome with 5.9 cummins and 4-sp allison trans. and 4-wheel disc brakes. The brake pads are getting real thin and i was going to put new ones in. Any suggestions on what pads to put in that have good stopping power? Hopefully i can just replace the pads without touching the rotors. Has anyone done disc brakes on a motorhome? It looks just like the ones on a car but bigger. Also, does anyone know what the torque is on the nuts on 19.5 wheels? Thankyou,Rod.
Old Jun 7, 2009 | 06:50 PM
wiskeyVI's Avatar
they shouldn't be any differant to chg than a car/trk set for that year.
You should have the rotors turned. They will last longer and function better.
If you have a diesel in it and use it regularly, you may consider installing a PacBrake to it.
Old Jun 7, 2009 | 10:45 PM
CrazyCooter's Avatar
What is the chassis? Chevy P-32? Osh Kosh?
Old Jun 8, 2009 | 05:10 AM
DieselDodd's Avatar
Its built on a osh kosh chassis which is now freightliner.The unit has an exhaust brake on it that is ineffective due to the non-lockup 4-sp allison. Where do you go to get brakes? Winnebego or freightliner?
Old Jun 8, 2009 | 09:05 AM
I usually get my stuff from Napa, but when it comes to those things, my local truck parts shops are usually helpful.
It may take a couple of phone calls to get all the possibilties figured out.
pullin hard
Mar 5, 2009 08:06 PM
n2moto
16
Jan 22, 2009 10:25 PM
ShawnQ
Jan 12, 2006 08:09 PM
wildcargo
Nov 29, 2005 04:20 AM
kwhite4
May 9, 2005 03:22 PM
