whats the trick to remove electric brake drums?
Old Jan 10, 2009 | 03:48 PM
jesussaves's Avatar
The electric brakes need some maintenance on my trailer but i cant get the drums off? Is there a secret that im overlooking? is it different than vehicles?
Old Jan 10, 2009 | 04:28 PM
bulabula's Avatar
Shouldn't be any different. Where are they getting stuck at?
Old Jan 10, 2009 | 05:26 PM
rich's Avatar
no trick just back off the shoes, sometimes you have to back them off pretty far because they will wear a pretty good lip. also try tapping them with a hamer to break them loose
Old Jan 10, 2009 | 06:33 PM
jesussaves's Avatar
thanks ill keep trying BTW my in-laws live in Harper
Old Jan 10, 2009 | 07:43 PM
rich's Avatar
nice little town sometimes those things can be a sob
Old Jan 10, 2009 | 08:27 PM
biododge1's Avatar
on my popup the wheel bearings need to come off with the drum to remove it
Old Jan 10, 2009 | 10:06 PM
Jeff in TD's Avatar
You should be able to feel if it is hanging up on the shoes, as you won't be able to turn the drum.
If you can still turn the drum, but can't pull it off, it's possible the inner bearing is somewhat stuck on the spindle. In that case a good yank should do it. If the bearing spun onto the spindle, though, you may have to use a puller to either get the bearing free, pull the seal out of the hub, or mangle the seal by pulling it over the bearing. Buy new seals anyway, as it's just not worth the couple bucks you would save to reuse old ones.
Both Dexter and Al-Ko have very nice downloadable pdf manuals for free.
Under "Service Information" select complete service manual.
http://www.dexteraxle.com/products___literature
And here, just click on "Owner's Manual".
http://www.al-kousa.com/
It is worth it to save both to your hard drive.
Old Jan 13, 2009 | 08:38 AM
jesussaves's Avatar
thanks alot! very useful info!
phishsandwich
Jun 8, 2013 02:18 PM
2500Ram
Nov 8, 2008 11:14 AM
watson14
Oct 6, 2008 01:20 PM
sleepr tsi
13
May 11, 2007 11:41 PM
Dodgezilla
Jul 17, 2004 05:24 AM
