What's the trick to remove the starter?
I've got a 99 3500 that the starter has decided to only work part time. Figuring it was the starter contacts, but wanting to be sure, I tried to remove the starter toady. I was unable to break loose the lower 2 12-pt bolts since all I had was a small 12pt wrench. Even if I had, I'm not sure I would have been able to get to the top bolt, or the wire connection on the top of the solenoid.
Is there a trick to get to those bolts? I can't quite reach that far from above, and can't seem to reach around the starter from the bottom.
I did manage to remove the cover on the solenoid to confirm that the contacts do need to be replaced, so I guess it wasn't a total loss.
Thanks,
Mike
Thanks,
Mike
From: In Oroville, Ca., same house for past 46 yrs!
I use a 12pt socket on my 3/8 drive ratchet with a medium length extension. I just used the "Ray Charles" method and felt over the top of the starter and got the socket on then reefed like a mad man with a short piece of pipe on the handle to break it loose. My stock starter was a 'bear' to get off due to those tight bolts. The rest is easy after the initial breaking of the torque.
Yep, and I bought a cheap 10 MM 12 point wrench, cut the open end off of it and made a extension to extend it about a foot for the lower 2 bolts. Made getting them off at least much less frustrating. Top bolt a long 3/8" extension and carefully twisting it knowing when it broke loose you were A) going to swear you broke something, and B) figuring you were gonna get a busted knuckle from hitting something with your hand.......
Place a folded towel on the front bumper to kneel on.
Place another over the air intake and lay on it to reach down to the top bolt with a 10mm and crank away....
Remove the easy to reach bottom one last and undo the wires.
Thanks for all the replies, guys. I plan on tackling this project as soon as my contacts and plunger show up from LarryB's.
I did just realize I may have done something stupid after reading a how-to on completely rebuilding the starter. As I said, I pulled the cover off the solenoid to inspect the contacts and also removed the plunger. The little spring came with it. I didn't realize there was a little ball bearing in there as well. I'm a little paranoid that it may have rolled out when I wasn't looking. I don't remember anything falling out, but there is a slight chance it could have happened.
What would be the symptoms of that ball bearing being lost? Would the truck even start? ( it started fine, by the way)
ive seen them at greggs. ive never needed more then a 24 and a can of wd40. after that your breakin bolts n sockets
have a look at the 3/4 drive sockets, the breaker bars for them are huge.
RoadDiesel
Aug 7, 2012 06:06 PM
jesussaves
Jan 13, 2009 08:38 AM
2500Ram
Nov 8, 2008 11:14 AM
Paradise Racing
Jan 18, 2005 09:08 AM
Dodgezilla
Jul 17, 2004 05:24 AM
