What would be your work vehicle choice here ?
This is true. However if the brakes are set up correctly, in the above described scenario, the unit or units being towed will automatically come to a stop, rendering your Class 8 tractor unnecessary.
Worked at Quality Drive Away for 6 years, now with Fed Ex Ground. I tow doubles ALL DAY, every day.
Do I meet your qualifications for being 'in the industry?
Seriously, since when is an extra axle to spread load, add an extra set of brakes, add an additional tire footprint to the road, and add wheelbase to the tow vehicle useless?
A 3500 and 4500 have a lower gvwr . Less payload , less money .
Stopping a load also depends on the braking ability of the tow vehicle . When a vehicle is loaded beyond its gcwr as most 3500's often are the braking is inadequate .
Super single tires ? I heard a lot of carriers that tried them are going back to duals . Blow a tire and most of the time you'll also end up replacing the wheel .
But no , as a former RV hauler now hauling doubles with a class 8 tractor I don't consider you qualified to give a response to the OP regarding the weight involved .
Seriously guys ..... this is about sharing information ..... the readers take what they want, what they determine to be valuable, credible information, do their own research and make a decision
You guys sound like school kids, whats next take out a ruler to see who has the bigger pp ? Give it a rest !
You make money deadheading by NOT spending as much money doing it. Everyone has to deadhead, just don't go broke doing so. Set up your truck to run both loaded AND empty at maximum milelage efficiency.
It takes ALL of a combination vehicles brakes to safely stop a loaded trailer. I'll let you in on a little secret, a Class 8 tractor trailer's braking system IN PERFECT WORKING ORDER is inadequate to safely stop a loaded semi truck on a simple downhill grade. We in the 'industry' call this a runaway.
And you think you can tackle this job with just the tow vehicle?
BUT!!! But sadly, the Super Single provides superior fuel savings over the dual, enough to justify the cost of changing the hub and wheel assembly.
As fuel prices rise, and they will, the industry changes.
Since day one , especially with LTL and a medium duty or Class 8 tractor . I know several hotshotters that went from 1 tons to medium duty because they were missing out on too many loads . Each one said they wished they'd made that move much earlier .
Bad advice should be rebutted .
Oh , I apologize . I didn't realize besides working for Quality and FedEx Ground you also drove for Werner and Boyd Brothers . Maybe if you told us how long you were with each carrier we'd reconsider your qualifications .
Mike D
Jul 13, 2007 07:23 AM
