Axle weight rating on trailer
Old Nov 28, 2010 | 10:29 PM
Spitse's Avatar
I have a 16' flat bed trailer. Where is the weight rating on the axle?
I somehow bent the axle up to where it touches the wood deck and so one tire is pointed out on the top and toed in on the bottom. I was wondering so I could price used vs new vs having the axle straightened. It happends to be the axle with the brakes also.
Old Nov 29, 2010 | 12:06 AM
JHardwick's Avatar
It should be on the mfg tag of the nose of the trailer. If not, maybe a tag on the axle, but probably not.
Best bet is to pull a hub and measure the seal diameter.
Old Nov 29, 2010 | 07:52 AM
electrifried's Avatar
how many bolts to hold the wheel on?
Old Nov 29, 2010 | 12:29 PM
Spitse's Avatar
It's a 5 lug. I know for a fact not ford pattern.
Old Nov 29, 2010 | 04:10 PM
Busboy's Avatar
Probably 3500lbs that would be very common on a tandem 16 foot with 5 bolt rims.
Old Nov 29, 2010 | 05:03 PM
samboats's Avatar
Smile
I agree with Mr. Busboy.....
Old Nov 29, 2010 | 05:07 PM
hardtarget870's Avatar
I saw a show on the Sunday morning Speed channel a few weeks ago that said you could tell by measuring the diameter of the axle tube. I dont remember the exact numbers, but Ill keep lookin.
Found a couple. I got them from another forum so I dont know the accuracy, but it might help get you in the ball park.
TrailerproPop 11-27-2009, 08:42 AM
2 3/8" diameter = 3500 lb.
3.0" diameter = 5200 lb, sometimes called 6000 regular duty.
There is a 4400lb. 3" also, relatively new, not that many around.
Old Nov 29, 2010 | 05:22 PM
Spitse's Avatar
thanks for the info. I now have to look for a replacement. Probably go to Tractor supply or Orschlans. They are close, like 8 miles away.
Old Nov 29, 2010 | 08:38 PM
J&L's Avatar
J&L
If your loactaed where I think you are check with Tulsa Auto Spring for strightening the axle/stub.
Also see A&N Trailer Parts inc--- Tulsa for Dexter axles.
Another sourse for axles is Starlite Trailer north of Claremore. I buy most my trailer equipment from them as their just down the road from me.
Most axles have a metal tag around the axle tubes somewhere with the axle capacity.
Old Nov 29, 2010 | 09:29 PM
Spitse's Avatar
Thanks J&L. I am at 69 and 412 so your suggestions are spot on.
Landini1
Apr 23, 2014 12:56 AM
bluesurf
17
Feb 27, 2006 11:31 PM
04.5HO600
Jan 2, 2006 09:25 PM
04ctd
Apr 5, 2005 11:59 AM
j28s
Feb 14, 2003 04:14 PM
