What is a going charge for hauling hay, cars, etc... Please help!!
Old Jan 27, 2008 | 01:16 PM
2500's Avatar
Let's say I'm buying some heavy equipment in Texas and I'm in Oklahoma... so I drive down in my 3/4ton CTD and 20ft trailer rated at 14k lbs to pick up the equipment. it weights say 8k+ lbs, so with trailer/truck/load I'm grossing out 20k+ lbs.
I've always been told that if equipment is owned by driver. and it's not a commercial for hire haul. then it's legal to haul.
otherwise every 10k lb RV pulled by personally owned 1ton or 3/4 ton CTD's or what ever would in violation.
Originally Posted by RickG
If you aren't crossing state lines FMCSA laws don't apply but check with state authorities . I know interstate haulers complain about OK being tough . I know KY vehicle enforcement likes to crack down on locals with 1 tons if they see them hooked to any type of trailer . That puts them over 10,000 lbs. gcw and the driver better have a medical card , DOT inspection on the truck and trailer and more .
Old Jan 27, 2008 | 06:51 PM
thewished's Avatar
Originally Posted by stock03
Most car haulers are rated for 5,200#. So how ever many bails equal that weight.
I meant FIT not weight. 2.5 tons would fit weight wise but I don't know if they will fit dimension wise.
Old Jan 27, 2008 | 06:59 PM
RickG's Avatar
There's a lot of variables here . No , you don't need authority with MC number to haul equipment you own . Be sure you carry proof of ownership . You will still need a medical card and DOT inspection on the truck and trailer as well as reflective triangles and a mounted fire extinguisher . You might need a log book , depending on how many miles you run . It might help to put not for hire signs on the truck . In your situation I really doubt they bother you .
Old Jan 29, 2008 | 02:38 PM
thewished's Avatar
Thanks, I always have a fire extinguisher after my alternator fire a few weeks ago... (stupid alternators going out)
And I don't have any signs of any kind for them to suspect I'm not hauling for myself, and I do have horses if they really want to get into it.
Do I have to go to a weigh station since my truck alone has a GVWR of 11,000lb's???
81turbota
Jul 27, 2014 07:49 PM
bowedup2003
Jun 28, 2010 06:40 PM
iweb
Oct 12, 2009 07:05 AM
Travs94Ram
Jun 16, 2008 05:05 PM
RAF
Jan 11, 2007 04:46 PM
