Water temp high?
Old Jul 28, 2006 | 08:47 PM
hllbllyhellion's Avatar
Water temp high?
I recently pulled the biggest load so far with my truck and I have some questions about the water temps. My truck runs between 195 and 205 degrees empty. Loaded it ran 205 rolling hills and on steep grades it got up to about 225, I was getting pretty nervous I had my xzt off the truck. So I guess my question is do these 600's run this hot or do I have a problem and need to go see DC? What temps do you see on your 600's? Thanks
Old Jul 28, 2006 | 08:54 PM
Hunter11's Avatar
I found that once I installed my Commander with my XZT that my stock temp gauge is way off. I use to get nervous pulling the 5th wheel in this 100* Texas heat because my stock gauge was above the 1/2 way mark by about 1/8th inch. Once I installed the Commander the first pull showed temps between 188* and 190* in the same heat and the gauge still above 1/2 way. I quit worrying after that.
Old Jul 29, 2006 | 06:26 PM
12valve's Avatar
can a stock trucks Water temp gauge be off?? or is the cummins simply overheating more then the PSD?
A buddy keeps telling me how HOT his brothers 04 cummins gets, and how cool his PSD runs! anything i can tell him?
Old Jul 29, 2006 | 11:17 PM
Once mine get's warmed up it never ever get's below 195 deg. I hope my gauge is wrong or I'll melt this thing down with a load on any long grade.
Old Jul 30, 2006 | 05:34 AM
Hunter11's Avatar
Like I said above, when towing our 5th wheel (11k) in 100* temps the water temp on the Commander will stay at 190*. On a big hill it may go as high as 193* but is right back to 190* when the road levels off. The stock gauge will be above the 1/2 mark the whole time.
I would be more worried about EGT temps on a long uphill grade under a load than the water temp. I have seen temps in the 1400* range on a long grade and have the Commander set to defuel at that temp to keep from melting the turbo down.
Old Jul 30, 2006 | 08:50 AM
Duallydog's Avatar
I think the thermostate on the PSD is supposed to come on at lower temps. Am I right? If theirs is set for 165* and is running 180* with a light load(which to me means they are having to fight to keep cool)(all theoretical, I have no idea what theres is set for) and our thermostates are 190 or 195s and don't rise much higher. I think the Duramax's thermostate is set fo 200 something.(I think)
Old Jul 30, 2006 | 10:09 AM
Hunter11's Avatar
My temp will rise to 190* and levels off there so I would say they have a 190* thermostat.
Old Jul 30, 2006 | 11:49 PM
12valve's Avatar
hmmm they dont have a pyro installed! and i wouldnt know how much theyr water temp rises! But They call the overall cummins as the overheating engine when towing. Thats the only thing they know to say aginst the cummins!!
Old Jul 31, 2006 | 06:40 AM
Hunter11's Avatar
Huh???????
Old Jul 31, 2006 | 07:03 AM
RAMRODD's Avatar
I had a 97,99,still have 05 6.0 powerstroke none of them ever had a overheat problum. I had a 2000 cummins and in really hard pulling in 100 + heat it would run a little warm up to 225 or so But the cummins could pull 70 mph in overdrive where the Powerstroke could only go 55 with OD locked out. My 04 cummins never ran above 200. yesterday my 06 in 112 heat with the TST on 2/2 pulling a gross load of 40,000 never went above 210 If that isnt a test of the cooling system I don't know what is!! The 600 series cummins do run warmer then the older cummins, my 06 usually runs 200 just driving it around empty. When it comes to exhaust temp the Ford runs a lot hotter then the dodge especially the 6.0. I found as a rule Add 150 to exhaust temp - 20 mph and that is how fast you will be going in the ford
Old Jul 31, 2006 | 03:46 PM
12valve's Avatar
Thank YOU SIR! Better info then i wished for! Do i need copyright for that last part? hehe? cuz someone told me cummins runs hotter on egts then PSD.
Old Jul 31, 2006 | 03:53 PM
DavidTD's Avatar
I was told all of the newer diesels run hotter for emission reasons. I do know my CR runs warmer than either my 12 or 24v but it never rises past 210 or so (just to the right of 200) on long hard pulls.
Old Jul 31, 2006 | 05:06 PM
staarma's Avatar
My 04.5 600 seems to run "hot" on the hills. I mean hills though. Talking about 9% grades, etc. With my Superlite loaded to the max ~8K and pulling a 7-9% in 90+ degree weather, I've seen 214 as the hottest water temp. My EGT's were steady at about 1230 and I was around 67 MPH with the hammer down. I had the Juice off and just the EZ on. When I turned the Juice on my EGT's dropped slightly and so did the water but by only 2 degrees and I backed off but maintained speed. My EGT's dropped about 100 degrees. If I had been in 100+ degree weather I would have seen 220 water temp for sure I think. My 2000 QC Dually with stage 1 injectors never would raise the water temp much above 200 not even on the Baker grade pulling 14K in August. I think these trucks are designed to run hotter all of the way around for the CAT's they come with.
schamran
Oct 29, 2013 07:06 PM
cwrhnr
May 19, 2009 05:18 PM
simonp
Nov 23, 2008 08:13 AM
turbox2
Feb 6, 2006 07:44 PM
firesine
Nov 24, 2005 10:58 AM
