Used alluminum stock trailer.
Old Oct 31, 2002 | 11:58 PM
tool's Avatar
Hey, I'm looking for a good used alluminum gooseneck stock-trailer.<br><br>I'd like one around 20'<br>Anybody know a good place to look for those?
Old Nov 3, 2002 | 01:11 AM
Srigs's Avatar
Re:Used alluminum stock trailer.
Go to horsetrailersonline.com they have the most complete listing and very good information. ;D
Old Nov 17, 2002 | 06:36 PM
XLCattleCo's Avatar
I agree with srigs, horsetrailersonline is the best web site for your search for stock trailers. Have good truck info also. Also have most manufacturers websites are also posted there. You are on the right track in going with aluminum. The weight savings are worth the extra expense. Good luck.
Old Nov 19, 2002 | 11:27 AM
tool's Avatar
I hear ya, alluminum is the only way to go as far as I'm concerned. Steel trailers just don't last. A couple years and they look terrible, paint peeling, rust starting, stone chips and the whole bit.<br><br>Have any of you had anything to do with Exiss trailers??? Looked at these last week, considering getting a new 20' gooseneck. They seemed like a decent trailer and the price was very competitive, so long as you don't want alot of options. I'd like one 8' wide but they are just too expensive. mthe 7' will have to suffice.
Old Jun 3, 2006 | 09:52 PM
BearKiller's Avatar
My main gripe with aluminum trailers is the way that the welds start vibrating apart, after a couple of years.
Does any aluminum trailer manufacturer make trailers with all steel neck structure with aluminum body??
The cut-gates and butterfly back doors should also be made of steel; as, aluminum doors are quite flimsy for a stock trailer.
Old Jun 5, 2006 | 10:17 AM
wyosteve's Avatar
Tool, where are you located?
Old Jun 5, 2006 | 01:49 PM
Dusty Ratcliff's Avatar
I like a barrett aluminum trailer, the corners are riveted on them instead of the normal welding & it lets them have some flex w/out breaking welds, I think?? the Wilson & EBY trailers are built the same way as well, neither are cheap, but for longevity & holding up in off road conditions I wouldn't go any other direction, I'm still a little partial to a Stoll pipe trailer though, yeah they rust, but if taken care of they offer many years of great service, I've owned two myself & my family has owned about 1/2 dozen, & my part of the country is literally full of them, they really are hard to beat, (several gooseneck brand pipe trailers as well, also an equally well built & tough trailer) for the $ you may wanna look into a good steel trailer depending on how often & where you plan on using it, if you're gonna be off the beaten path alot while loaded I'd probably lean towards the steel trailers, but that's just my opinion???? hope it helps some, Dusty
Old Jun 15, 2006 | 10:46 AM
telephonman's Avatar
BearKiller, I have a Bison Horse trailer that has a steel gooseneck coupler and steel frame with an aluminum body, not sure if they make stock trailers you can check them out here....www.bisontrailer.com
Lucas1
Oct 27, 2010 02:35 PM
hitcb1789
May 25, 2010 09:10 AM
jdwest
Jan 21, 2007 07:57 PM
fsthrse
Apr 29, 2004 09:14 PM
therobzilla
Mar 29, 2004 02:13 AM
