Truck and trailer huck a bucking
That's what I call it. First time pulling 5er 31 ft long, on most roads you fill like your in a rocking chair with the grand kids behind you. i have a 02 3500 auto dulley,trailers has no shocks. Pull trailer 4 times interstates not too bad.Any thoughs?
What your feeling is usually called "chucking". I towed a heavy Travel Trailer for over 10 yrs. and never had the problem , as soon as I got my 5th wheel I started feeling the bucking. Installed a set of Firestone 5000 airbags and the problem is gone.
Just a plain ole guy
Tires at full cold inflation and a wdh will help too. Also how you load it can have an affect as well as how the wheel base works with the road surface.
Tire pressure on trailer 55psi cold, D rated tires. Can only check outside on truck, Firestone dealer installed short stems, have to make another trip and have tires re-stemed.
Is the trailer running level? This is typical of a trailer running nose high. Low pin weight will also cause this. Try adding some weight in the front storage and see if that helps. A 31' should not stress the suspension of a dually 3500which would imply you do not need to stiffen the suspension. Mine is 37' and does not chuck - - but it did - - oh yeh. I added an Air Safe hitch and almost all of the chucking is gone and the overall ride is much better.
Bob
Bob
http://www.genosgarage.com/prodinfo.asp?number=AP4
MikeyB
You may want to weigh your truck and then weigh the truck & trailer. You will see how the trailer is distributed on the truck. This may give a better idea on what is going on.
JTBbudman
03-04-2015 07:48 PM
