Truck to high for 5ver
Originally posted by Jack Thorpe
HA! I got some information from Dodge today. Apparently they have been having a lot of complaints about this new body style and the height of the truck. Their engineers are working on a kit right now that will lower the truck by a few inches, while keeping the driveline in the same condition from the factory. What I mean is that this kit allows for lowering of the truck without screwing up the balance of it. They also say the older kits will NOT work without some major modifications to the kit.
If you know anyone who's been looking for this information, pass this post on to them. I know there have been a lot of questions about it in the past. When I find out a timeframe for the kit to market, Ill let you know.
Re: Truck to high for 5ver
I've got an issue, guys. I bought this 04 dually in Sept. and it's too high for the trailer. I did go on one trip with it and it seemed okay, but I took it by the rv dealer today and they said it's about 2-4 inches too high, maybe more. The trailer does look like it's doing a bit of a wheelie now that I look at it closely.
Here's the issue. The axles can't be flipped, and I can't lower the hitch because of some of the locations I need to park the trailer. I guess I have two options, lower the truck or find another way to lift up the trailer some. Anyone experience this? Any advice? Thanks.
I just went through this issue in March after placing an order for a new 2 horse gooseneck from Sundowner Trailers (Coleman, OK). Sundowner recommended a minimum clearance between the bedrail and the support frame of the gooseneck of 6 - 8". As the gooseneck frame on the trailer was 61" from the ground with the trailer sitting level and a 57" bedrail height, I had about 4" clearance.
I was told by Sundowner that my empty trailer would have a pin weight of approximately 1200#. To test the "squat", I loaded the truck bed with 1200# over the axle and measured about 2 1/2" squat. This resulted in a clearance of 6 1/2 inches, which I thought was a bit tight. After considering options, I decided to have the trailer axles blocked 1" to increase the clearance to 7 1/2 inches.
I am pretty impressed with Sundowner Trailers Inc. Their engineers were pretty close with their calculations. When I picked my trailer up in Northfield, MN two weeks ago, with the trailer sitting 1-1/2" high in the nose (on level ground), I had 8 1/2 inches of bedrail clearance. After loading two horses, the trailer was sitting 1" high in the nose (no big deal) and I had about 8 - 1/4" clearance. I ultimatley lowered the gooseneck to level the trailer and now have 7 1/4" clearance - or about the middle of the factory recommended clearance range.
For the posters who say travelling down the road with the nose high (or low) on a 5th wheel or gooseneck is not a problem; I can't agree and I think such advice is ill informed and possibly dangerous. Changing the angle of the trailer changes the weight load on the trailer axles as well as the pin weight on the back of the truck. This can have disasterous results on handling and control. Sundowner does not recommend a rise of more than 2" (max) and states that a lower rise is desireable. I think anyone recommending pulling a "nose high" trailer should check with the trailer manufacturer before giving such advise to others.
If I had the option of a factory kit to lower my truck, I might have considered it, however without a kit, I was concerned about problems I might encounter with driveline angle changes. The cost to block the trailer axles was about $100.00 and although I was hesitant to raise the trailer's center of gravity, Sundowner was not concerned about the increased height and my towing experience has been very good.
In my opinion, short of a factory kit (to lower your truck), I'd block you trailer axles and pull a level trailer.
PS If you would like a list of truck bed "squat" measurements with different bed weights, just let me know (I tested 1,000 - 1,500# loads before deciding to block my trailer axles).
Tommy93w350
Jul 16, 2007 06:54 PM
